  • Replies 186
Posted Images
I got blitz. I like it. Bit big though. Can almost fit head in there lol. But it goes nice.
lol i dont mind how it looks. i just want it to perform well.
Cam - this is true. they are japanese and are pretty much 20 years ahead of us.. maybe just get it and ill edit it to be 'free flowing' if need be..
i like the Kakimoto!!
So get the Kakimoto!!
The blitz is quieter then the legalis? Holy cow...I would think the Legalis is probably the quietest aftermarket exhaust I've heard...
yeah, my Nismo exhaust is also quieter than the Legalis, although not by much and I am more going off what friends and family (they hear me when I roll up and drive off). This is purely due to a different rear muffler design to the Legalis (the rest of the unit is essentially the same).
The Kakimoto will be about the same volume as the Legalis but should have a deeper grumble.
thats exactly what i want!
jesse Streeter said $950 delivered brand new in about 6 days :)
me starts saving me thinks~!
WTF - that's freaking CHEAP
the fujitsubo is a more expensive exhaust in general, but on that Im just waiting on responses for what available in Jap.
Yeah, but don't you have to cut it to fit within the 1.5 max parcel size?
(Yes, I know you can get it welded, back together but still)
yeh the fujitsubo is 7cm too long to get air freighted, so he said he can cut one pipe in half for like an extra $10 or $15 dollars, which is much cheaper than having to pay extra for a bigger box.
unless I wanna wait 3 months and have it freighted with his next shipment. but im an impatient bugger.
cutting the pipe would definitely not effect performace. he said he'll mark a line to match up the join again when its hear... not too fussed. maybe it will fit better with a cut as I can adjust it.
fujitsubo Legalis R (2nd hand)67,000 yen .. i think this is the go. just waiting for confirmation on whether thats shipped or not.. he seemed pretty exited in the email lol
LOL Streeter is a champ.
Hmm this sounds all too familiar...about the cutting and the welding. In the end the Legalis I bought was air freighted over without any cuts, so I don't see why you would have to if you bought the same exhaust...
The Kaki on the other hand....:whistling:
Hmm, these were the prices I had for the exhaust when I last spoke with jesse (these are brand new prices)
Kakimoto R Muffler - 50,520yen. 1 in stock.
box size is 1800x350x450mm
Fujitsubo Legalis R Muffler - 67,400yen. few in stock.
box size is 1570x620x320mm
He did say the kaki is def over the 150cm limit...
I paid 48,500 excluding shipping on mine...
thats what he said so Im guessing its not including shipping. well i have about 1,000 to spend on the exhaust, plus whatever Scott wants for the front pipe.
any one got either the legalis or kakimoto
which do you reckon is better
either one of those to ill get
i want to get the takeros full titan yet the pipe is 100mm , larger then the desired 80mm for better flow as all the decate pipes are all 80mm as well
scotts gotten 300awkw with a legalis, and a self fabricated front and dump pipe with a 100 cpsi cat.
i should have the kakitmoto by mid march and a tune and should be able to let you know..
300 awkw with just the exhaust mods?
Er, no.
I'll let Scotty fill you in, but suffice to say it's been EXTENSIVELY developed.
R.I.P.S have quite a job ahead of them.
Edited by Daleo
lol no, im just saying it was able to handle his other mods and flow enough.
to agree with dale, RIPS are in for a good nightmare, and you should have a nice bill lol
    • That M3 looks like it handles so well, initial slight understeer on turn in followed by oversteer which is cancelled out as steering returns to centre. Looks like such a fun car to drive. In comparison the Skyline and Sierra look like they understeer more and thus need more heavier steering inputs...?
    • Gday   on the hunt for an rb25 gearbox and clutch to go into my R32 rb25/30 build happy to travel a bit or pay for freight for the right one From my limited research, think I need an rb25 driveshaft yoke to make it fit so I’m after one of those too located Bathurst
    • Common for single gauges to be swapped around. My 33 GTST when I bought it had a GTR tacho fitted, everything else was GTST gauges.
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
