  • Replies 186
Posted Images
Soichi said he hasnt put it up on his page yet but he sent me a link to a tuner mate of his in wellington
http://www.speedtech...ent+System.html
and said all that you read there he can do
as in use the hks ecu as a piggy back install yet a stand alone ecu
and they have off the shelf harneses for the vq25det , he says look further down at make and model and ull see vq25det
Edited by Sidius
so why cant the nm35 run a stand alone ecu
wouldnt it be like any stand alone ecu
new ecu goes in and tuning , maping is done
all i know he said around 4g for full stand alone installed
beacuse like the gtr it has a whole lot of other shit to run off the factory ecu.
let him know its just a plug in loom with fcon and m35 and see what he says..
Haha, 2k for an install with a plug and play harness, I need to get on that gravy train... Even if it is tuned that's very expensive.
For 4k I would be putting a Motec M800 in I think.
At least you have an authorised HKS tuner around the corner, I would have to drive 1000k's
as scott said.
got the kakimoto R exhaust. i have not seen an exhaust where you can see straight through the 80mm of goodness(pipe) lol
for an exhaust shipped for $1000 i think its the best ive seen. cant guarantee it being quiet though :P
flames will definitely be happening. *looks at craig*
as scott said.
lol lets have a loudness competition when mines done :P
lol your using a flappy thing though arent you? or changed your mind? i have a feeling mines going to be louder than before, its seriously a straight through pipe. im amazed its beautiful lol.
^^lol show off
well heres some better and more accurate pics of the kakimoto system.
this is what came with it,
this is the mid pipe hotdog styled mufffler - straight through
and the tail pipe muffler - straight through.
can't wait to get this exhaust on.
^^lol show off
scotty got any pics of ur front pipes, race cat and downpipe , my kaki n1 full mega is on its way
I don't even have the turbo yet buddy... Give me two weeks, unless you mean the old system? I fit it into Sage's car last night.
f**k i still want this 3.5 inch u ass.
Sidius, you wanna buy my dump off me? lol
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
