I want to change my gearbox oil and diff oil. I know that Redline is one of the best oils for a car's gearbox. Helps synchro's work better.
BUT. I remember hearing/reading that the lightwieght shockproof gear oil is corrosive for the gearbox.
On the website it says:
A unique gear oil designed to lubricate racing transmissions and transaxles which see serious loads (not recommended for most syncro-type transmissions).
Does that mean it will corrode your gearbox. I also hear it only lasts for 10,000kms. Not 80,000 like normal gear oils.
And will that corrode the LSD of my R32, with a RB25DET engine and box.
So I was wondering if I shoudl just get Redline superlight shock proof oil. Or Royal purple maxgear.
  • Like 1
https://www.sau.com.au/forums/topic/267969-gearbox-redline-oil-vs-royal-purple/
I have only had good experiences with Redline Shockproof oils in my R33 GTS-T.
I run Shockproof Heavy in the diff and it has tightened up the diff quite nicely. I also tried it in the diff of my R33 GTR but it tightened the diff up too much to the point where it was becoming more of a locker so I swapped it over the Motul instead.
I have used Shockpreef light in my GTS-T gearbox with no problems. It seemed to smooth out the synchros and improves gear changes. I change my drive train lubricants every 20k and they come out nice and clean. My son then reuses the shockproof light in the gesrbox of his Mazda 626 with no problems.
Redline oils are expensive and these are my experiences.
shock proof is recommended for gearboxes that are in good condition it is able to be used in syncro gearboxes but only if they are in good nick no syncs crunching and all that otherwise your box will have a much shorter life i run heavey weight shock in my rb25 box and its great smooth shifts and engages great recommended it but be prepared to choke at the price
My memory is opposite: MT90 for good condition transmissions, light shockproof to help worn synchros work better (so postpones the inevitable gearbox rebuild). Ring Redline for confirmation.
I emailed them. I hear the distributor is in Ozy Park, So I will call them.
Yeh, pretty sure shockproof is only for race use and worn box's. Not good condition ones. Its either too slippery or just corrosive
^^^i was also under the impression to use it on race cars or worn boxes.
was thinking about putting it into my rb25 box but am a bit undecided if i should use this or use castrol vmx80 with nulon additive.
my gearbox crunches 2nd unless i shift at quite low revs :)
Redline is a real good brand. The normal MT-90 oil they do for good condition gearbox'. Thats what I recomend
MT-90
Popular in Nissan, Toyota and Mazda manual transmissions and transaxles as well as other selected applications, this is a 75W90 GL-4 Gear Oil that’s slightly heavier than MTL. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting.
Car - Nissan - Skyline
All-2001 GTS & GTS-T (single turbo) (R32,R33,R34) RB25 & RB25T Eng, 2500cc, 2WD
Component Recommended Oil / Fluid
Motor:
Select your closest climate range. For -10°to25°C use '5W40' or 5°to35°C use '10W40' or 15°to50°C use '15W50'. (* Racing Only - use Race Oils) @ see handbook for Litres
Manual Gearbox:
Select your closest climate range. For -10°to25°C use 'MTL' or 5°to35°C use 'MTL' or 15°to50°C use 'Superlight Shock'. (* Advantage option for Performance / Racing use 'Lightweight Shockproof'.) @ see handbook for Litres
Rear Diff:
Red Line '75W90' Gear Oil (* Advantage Option for Racing use Red Line 75W90) @ see handbook for Litres
Power Steering:
Red Line Synthetic Power Steering Fluid (Bar Code Nos 30404 or RL182-1) @ 0.9 Litres = 1 US Quarts
Cooling System:
Use WaterWetter (Pink) to improve temperature control and reduce corrosion. 1x355ml bottle with distilled water. @ 1 Bottles
Fuel System:
Red Line 'SI-1' Fuel System Cleaner. 1 bottle in petrol tank every 10,000 kms. @ 1 Bottles
Edited by reNEGaDe88
what i have been told is that although the shockproof oil makes your old gearbox good again it is not designed to make it last in other words it will fix all that crappy things happening but it WILL wear quicker and give up quicker than if you were not running it . so if efficiency is your aim then yes use it if durability is your aim then it is not recommended take notice or not i dont care i run heavy weight in my box i would not run light or super light personally and i dont care how long my box lasts as long as it is working at 110 %
Yeh, I want new oil for my gearbox to feel a lil bit better and last long. So I would need something like Redline MT-90 which lasts for 80,000km, unlike lightweightshock proof which lasts 10,000km, and box wears faster.
Cheers
Where did you get that info?
FWIW the standard interval is 100,000 and that's for mineral oil. Synthetics should be more like 300,000.
What a load of crap. I put redline shockproof in about 3 years ago. About 1.5 years ago we changed my clutch and took the fluid out, it looked brand new so we decided to reuse it. I've had the same lightweight shockproof in there for about 30,000km and it still feals like a new tight box.
Nissan recomend you change your gearbox oil every 80,000km. I read that the Redline Lightweight shockproof oil is for race cars with dog box's etc. So it made to give max performance not necessarily max duration. So it only last 20,000km before the compounds of oil break down...
Hate to disagree with again on a different thread but thats incorrect
I have a bottle of redline oil (light shockproof) which i used on my gear box. It says on the bottle that the oil is good for up to 400 000kms.
Ill upload a pic when i find one on my pc.
EDIT:
Found the pic... You will probably need to zoom in on the sticker that has been circled in blue (Save picture as then use windows picture view to zoom in). The bottle is at my workshop. Next time im there ill snap a better pic. But this will have to do for now.
Or alternatively, go to this link.. is a bit easier to see
http://i292.photobucket.com/albums/mm33/br...n79/redline.jpg
Edited by br3ndan
I used redline lightweight in an RB20 box that ran no oil in it for a month.. i bought the car, it whined like a bitch, thought it was almost dead, thought id have a look in their and not a drop of oil came out. so i filled it up with the lightweight and it's good as, been good for 6months now and i thrash it hard.
Cheers
I'd recommend something other than Redline MT-90, when discussing with someone else who regularly uses Redline he recommended Redline MTL, MT-90 is quite thin.
Note: I'm talking about R32/R33 boxes, not R34....
It doesn't work well for my series 3 R33 GTR box (its 10 years old so maybe its worn synchros), so I'm trying Castrol Syntrans 75w85 next
sorry for double post. But I found this on redline tech sheet
CORROSION PROTECTION
The extreme pressure chemistry used in many gear oils
can be corrosive to brass and bronze used in synchronizers
and bushings. Most gear oils are corrosive at
temperatures of 200°F. Red Line Gear Oils are non-corrosive
up to 300°F and the MTL® in excess of 375°F. A
corrosive gear oil can shorten synchronizer life by half
and can also contribute to rust problems.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
