Model: 2001 EVO VII GSR JAP SPEC
Condition: Excellent
Sunroof: Yes factory fitted from Japan.
Colour: White
Kilometres: 67XXX
Motor Kilometres: Less than 8000ks
Price: $43K
Reason: Looking at purchasing my first home.
Contact Details: Ken on 041 347 0001
The time has come to sell my white EVO 7.
Some of you older members are aware of this vehicle.
I’ve owned the vehicle for more than 2 years now and I’m the first owner in Australia. Car was imported by Jap Link and was in complete stock form. Vehicle was inspected by State Road at the time of purchased and was in tip top condition, will provide the statement to new owner.
No expense spare on Modification.
All Mechanical work/service was perform by one of the EVO specialise known as BEL Garage.
BEWARE: This motor is capable of handling serious horse power.
NOTE: Not your average EVO :tongue:
Full completed Cosworth Crate 2.2L Short motor.
- Forged Billet Crank
- Forged Pistons
- Forged H beam Connecting Rods
- Race Bearings
Cosworth Short Block Assembly Mitsubishi EVO VII-IX 4G63 2.2L 01-07The Cosworth 4G63 2.2L stroker engine combines the perfect bore to stroke ratio, yielding potentially big gains in torque while still allowing the engine to rotate and produce power higher rpms. This is the perfect foundation for your big power engine build. Combine with one of our CNC ported Big Valve Cylinder Heads and Camshaft sets for maxiumum reliable power.Specification: Each Cosworth 2.2L short block features: -Cosworth Forged Pistons(86mm)-Cosworth Forged H Beam Connecting Rods -Cosworth Billet Crankshaft (94mm) - Cosworth High performance Rod and Main Bearings -Cosworth High Performance Main Bearing studs -New Mitsubishi 4G63 Block. Each assembly is carefully blueprinted and balanced and includes a build sheet listing all critical dimensions.
- Evo VII head worked, capable of flowing more than 30psi and Nitrous
- Cosworth Camshafts M2s
- Cosworth Complete valve train kit
- Cosworth Head Studs
- HKS Cam Gears
- HKS timing belt
- Garrett GT35R turbo
- Tial 44mm External Wastegate
- Full Race turbo Manifold
- Hypertune Plenum
- Hypertune 77mm throttle body
- Hypertune twin entry fuel rails
- Hypertune custom intercooler piping
- Hypertune custom 4” intake pipe
- Hypertune custom air box
- Hypertune custom Oil catch tank
- Hypertune custom 3"dump/front pipe
- Hypertune custom surge tank
- 3” Catback Exhaust
- Earls Teflon braided fuel lines all round from back to front.
- Bosch 2 x 044 Fuel Pumps
- Sard 800cc injectors
- Sard fuel regulator
- Walbro Intank Fuel pump
- Ralliart pulleys replaced all standard pulleys
- Ralliart Spark plugs leads
- Power FC De Jetro ECU
- HKS EVC Boost Controller
- ORC twin plate Carbon clutch rated 900hp
- EVO 9 RS 5speed Gears box
- EVO 8 MR Enkie Wheels & Tyres, ( Plenty of tread left )
- ETC ETC ETC ETC
Car has easily run a PB 11.5 at 127mph (2.01 60ft) (first shakedown run) makes well over 300kw atw on only 1.5bar of boost using petrol station pump fuel.
There are still plenty of potential within this setup, the power its making, is only in its early stage and is NO where near the limits. Plenty of head room for new the owner to take it to next level with a ultimate E85 tune.
There is plenty of directions for new owner to turn this vehicle into Time-Attack machine or Drag Monster etc etc. :biggrin:
Car has been built to be reliable and has NEVER fail on me once.
Car has never been in an Accident.
More pics can be found at :
http://www.belgarage.com.au/index.php?opti...&Itemid=106
If you do the maths, My loss is your GAIN.
Strictly no joy riders // No Jet pilot.
Looking for a quick sale.
Serious Note: Serious enquires only please, May consider trade BUT cash my way depending on vehicle, Low ball offfers & Time wasters will be ignored. Thank you.
Welcome for any inspection for serious buyer.
[ WILL NOT SEPARATE ANY PARTS ]
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
