  • Replies 88
Yeah we gave it a bash yesterday - only did a hp run though - too hard to find enough cop-free road to get up to the 170km/h or so needed to do a 1/4 mile.
Anyhow, the hp came in at around 220hp (160rwkw), but this is low. It was done on a bumpy piece of road, I lost some traction and I think the bumps messed with the figure.
Check out my dynos here and the one with torque figure here. The red figure is the pre-latest mods and blue is current. While the peak power figure hasn't gone up that much, the mid-range torque and power gains are excellent. Note too, that at afr's of around 11:1, it is a conservative tune, with plenty left in it. However, I don't want to blow up my engine, so I can run it at this figure all day without risk.
Hope to catch you all at AIR next Wednesday - it is going to be a massive night, with some nice cars heading out from NS.com and PSI too! The best bit - NO V8s or slicks .... only true 4 & 6 cyl street cars!!
https://www.sau.com.au/forums/topic/26798-18th-oct-cruise/#findComment-565973
I believe gates open at 5pm, racing starts at 6pm. I hear rain may be forecast, but you never know. I think it is $17 to spectate - about what you pay for a movie, but with MUCH more excitement!! :P
https://www.sau.com.au/forums/topic/26798-18th-oct-cruise/#findComment-566168
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
