hi people, just a quicky, fitted a boost controller today and running a heathy 9psi,
going to fit a gauge this weekend and wondering where you have mounted yours and what sort did you get ie electric - mechanical and how hard was it getting the hose/cables through to the engine bay,
any help from you stagea gods would be awesome its a s1 by the way :P
https://www.sau.com.au/forums/topic/267982-boost-gauges/
  • Replies 59
looks in the way up there, i did look at them but in my opinion the whole mount looks cheap, think i may go pillar mount or like QWK32 done. just need to find a good looking mount, and a good looking gauge 2moz. ill post pics up of mine when its done!!!
https://www.sau.com.au/forums/topic/267982-boost-gauges/#findComment-4568983
I am installing mine in the rh side of the centre vent. I have taken out the movable vanes. I guess I am lucky to have a spare vent if I want to return it to stock. Its an electrical type with the sender mounted on the engine bay.
I would have liked to have it on top of the dash but it would look rough from the other side (i.e. looking in through the windscreen). Plus I want my car looking as stock as.
My last one was mounted below the radio but its too far out of the line of sight...especially when you're trying to adjust your boost controller and coming up to a bend at ###km/hr!
https://www.sau.com.au/forums/topic/267982-boost-gauges/#findComment-4569006
Made my own ,out of fibreglass and vinil and put it between the pillar and the vent...looks a little bit rought but its hard to catch at first sight :blink:
The line for the sensor comes trought the dash an the cover of the side panel
https://www.sau.com.au/forums/topic/267982-boost-gauges/#findComment-4569110
QWK32 looks sweet, mine wont be a defi gauge though lol, looks like u put the cable through the top dash vent, looks neat, how did you go about getting it through there was hard??
nah i just run the cable down the side of the dash in the corner. defi's are all electric gauges so i had no vacuum line to worry about. here is a pic, just ignore the dirty windscreen :)
https://www.sau.com.au/forums/topic/267982-boost-gauges/#findComment-4569215
if i could post the pic of what i wanna do but cant cause its a bitmap.
where the ash tray and lighter is, put a 3din in there and have oil temp+press and boost. but need five gauges all so it might change.
was thinking 2 in each corner of the cluster. plenty of room in there to fit them.
(thread steal) post up all your gauge setups people. be nice to get some pictures to some of our ideas :)
https://www.sau.com.au/forums/topic/267982-boost-gauges/#findComment-4569327
Made my own ,out of fibreglass and vinil and put it between the pillar and the vent...looks a little bit rought but its hard to catch at first sight :)
i have a mearcat one that looks like this. Very subtle IMO and easy to see.
https://www.sau.com.au/forums/topic/267982-boost-gauges/#findComment-4569340
When I bought mine some one had already made up a pod thing which i don't mind but it is a bit low, It is nice and neat and out of the way and wouldn't be
to hard to make
holy shit. thats it. i want mine there!! for my transmission though. had some work dont to it, need to keep eye on things !
https://www.sau.com.au/forums/topic/267982-boost-gauges/#findComment-4569842
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
