  • Replies 277
Posted Images
Got these back from the ceramic coater today.
Spent a few hours porting the standard ex manifold, i know you can't polish a turd but at least you can help it flow a little better;)
Still waiting on the adaptor plate :)
BTW top gunnesssssssss isn't a word :D
Tuned length...... hrmmm
I'm thinking inertia and friction loss... That loop backish style of pipe work isn't all that good for flow.
Visualise sliding down a water slide as a child... you'd drop some serious speed.
However I really like the look of that cam belt alloy looking fill in section. :D A++
Edited by SLAPS
  • 1 month later...
**Small update**
Bought a ProEngines adaptor. Beautifully made, packaged and sent within a of ordering!! Thatis service
Here is the engine with her skirt up getting some attention
Also ordered a nice hose kit to replace all the old lines :laugh:
Gearbox was also reconditioned, has all new bearings and synchro's as well. Should be great.
Ended up being able to get the single plate cluto hold the 600ft/lb clamping force i was chasing as well, so that is great. NISMO slave will help with clutch pedal force required :laugh:
Unfortunately its slow going, but we all have bills that need to be payed before the fun tickets can be spent on the engine....also rebuilding the gearbox and giving the head a light freshen up for the Sil80 doesn't help much... :)
**another small update**
Engine is back in the car- hoooooooray!!
It's not plumbed up but sitting in it's modded mounts and funilly enough, no bonnet issues!! :blink:
Still wearing the old cam covers so nothing was scratched during it's install, but here she is
And this is the delightful little darling that's supposedly going to hold the 600ft/lbs
It's not plumbed up but sitting in it's modded mounts and funilly enough, no bonnet issues!! ;)
Whoa, whoa, whoa... now you've got my attention. Tell me more - how is it you have no bonnet issues? What Modded Engine Mounts? Sump still clearing the crossmember??
yep! You definitely got the need for speed!
I hear if you can fly a plane you can make an engine fit! Its simple maths really...
But on a more serious note its looking good mang! You can take me for a drive when its done ;)
The modded mounts is pretty simple, it actually sit a little too low on the drivers side so we spaced it up a slightly. The sump clears the cross member by ~3mm.
I could show you but then i'd have to kill you :)
hmm... 3mm. Any danger of hitting it when the engine torques?
Have you got the front cam cover on it with the bonnet down?
Not with the bonnet bolted into place but sitting on there yes.
**update**
Very excited- Car ran today for the first time!! Wouldn't believe it but started within 1 second of cranking and oil pressure immediately. Very happy.
Few little problems. An oversight by me, engine was originally going into my 4 door 32, but then i bought a GTR. The balancer is an RB25 item, i now need a 26 as obviously the power steer doesn't line up. Yes i could space it out but i'd rather fit the correct item. SO more delays in tracking one of them down. So if someone is building an RB25 an wants a Ross balancer....
The water bleed was blocked but after some persuasion with high pressure air that was sorted. Started run-in on the dyno but rear wastegate circlip came off so that ended that.
Otherwise the gearbox is nice and tight- nothin like a tight box :( and the clutch is soooo light it's not funny. You'd never know she'll hold 600ft/lbs!!
Plus she has that nice 3 litre growl ;)
I"m uploading a short vid but it's taking a long time.
Shit pic but just before it's first start.
Edited by Simonster
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
