  • Replies 277
Posted Images
Unfortunately not until new year now, won't start it again without the correct balancer.
She punched out a massive 200hp on 6psi with some terrible timing :rant:
Bonnet didn't shut in the end, fowled on twin turbo pipe, so that's being changed to sit lower.
Twin turbo pipe changed, bonnet closes like a dream baby :)
Pick here up monday :)
What pipe are u running out of interest? All i did to mine was remove the twin turbo badge then grind off the boss which held the badge, about 10mm off the height was saved :blush: then craved coatings gave it another fresh coat and it was just enough to clear the bonnet. Have u still cut the bonnet bracing or does your new pipe allow for this?
What pipe are u running out of interest? All i did to mine was remove the twin turbo badge then grind off the boss which held the badge, about 10mm off the height was saved :) then craved coatings gave it another fresh coat and it was just enough to clear the bonnet. Have u still cut the bonnet bracing or does your new pipe allow for this?
Hi Marko,
He didn't say (car still in workshop) other than the bonnet closes. He did say he didn't need to cut the bonnet though :blush: i'll see it on Monday and let you know. Great work you were able to make yours fit :)
I can't wait to drive it- it's been 6 months!
hahah, simon i fly into brisbane monday, i'll come drive the 4door home for you, just to get to see the 3ltr gtr up close :D
Haha My 3ltr bottom end gets sent this week finally, yay, so i might start my own 3ltr build thread soon !
Gary
Could you clarify on the "modded mounts" please :banana:
takes about 5mins.... ours literally sits on the xmember... we have to re weld removed material to bring it back up a bit :banana:.
takes about 5mins.... ours literally sits on the xmember... we have to re weld removed material to bring it back up a bit :D.
If i drop the xmember 15mms and do you think i could fit this http://img.photobucket.com/albums/v489/r32...at/DSC01070.jpg
hi-mount turbo without affecting the suspension/awd? (HKS kit which currently needs the bonnet frame hacked to clear)
Same turbo kit as this car
i dont think dropping the engine 15mm will solve the problem - besides that, when the engine twists under load it will still touch the bonnet bracing.
are u sure u want to drop the engine lower? ...i was advised by rob @ rips not to do this as it changes the geometry of some of the important components i.e. cv joints
Cheers for that Marko, guess i have to find another way to make it fit :D
sorry for hi-jacking your thread Simonster
well i cut my bonnet to fit my rb26/30 (to clear the cam shaft covers & twin turbo intake pipe) - if u dont like the look of cutting the bracing u can simply just refit the bonnet insulation & u wouldn't even know it has been modified :D
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
