  • Replies 277
Posted Images
Marko we all know the reason you don't like rb30s is it had to much low down torque and you looped it and smacked a wall
We ALL know? You are a champion lol and I must say, thank you for sharing that - 10 points to the man with the microphone! Besides, I wouldn't go shooting off remarks like that unless you understood the root cause and in fact why the rear tyre peeled off the rim.
Your comment has no validation to capacity what so ever.
I had the opportunity to keep my rb30 and decided not to which clearly demonstrates that I prefer an rb26 and subsequently have my old car back...I've been there and done that, I've had my fair share of clapped out imports and now have my aust gtr :)
Tyres don't just peel off, I'm sure you know that, the force required to unbead the tyre from the rim is quite substantial and could only be caused by the rim/tyre impacting the gutter or pot hole from hell
I have seen tyres go flat and people drive on them until the side wall separated from the actuall tyre, but the bead was still attached to the rim.
As for capacity, on the street the rb30 would always be the best choice. cause I like drive up a hill with my a/c going and not have to change from 4th to second to get up there
Edited by r32-25t
How can u draw a conclusion when u don't know the sequence of events? This is way off topic and again simon, I apologise.
Sorry if I have been abrupt but I shouldn't even have to apologise on this front...
Rb30 is an awesome engine, so is the rb26
How in the world did we go from tyres issues to aircon. WTF?? :pirate:
So back to my build thread rather than chat thread. I don't at all mind the banter thats been going on in this thread for the last 2 weeks or so, as long as its helpful.
I hope to twist my other tuners arm this week and get the GTR on the dyno to see what he thinks is going on....
  • 3 years later...
Just read the thread, I see this finished mid 2011, does it still stand true that the 26 is better on the track than the RB30, the Nitto 3.2 strokers rev to 10,000 and do not seem to drop off after 7000rpm and continue to go hard to the limiter??
Maybe I misunderstood ?
No its not true that 26s are better on the track. It is true that there have been a few more highly developed RB30 32 and 34s built in the last few years and they can indeed rev to 10k but at the end of the day , when all's said and done etc etc the fastest car on the track will be the best built best driven car and the capacity will just be a factor, not the deciding factor.
Yeah, after reading a lot of builds it seems the strokers are starting to be developed to rev higher as well as having the low/mid grunt.
Seems the Nitto 3.2Lt seems to be a well made unit and can handle a heap of HP while revving to 10,000+
I am building a Nitto 3.2 but as a DD and probably limited to 8000rpm ish depending how it all works in together.
You will be aware that RIPS put a 3.2 (pretty sure it was a Nitto) in a Stagea and made 1000kw...
Rips have put them in a few Rs, MGAWOT 1 & 11 and @ 1500HP, they seem to do some amazing things. Nitto in QLD goes hard @1000HP+ :) CRD has done some quick Rs
    • Por qué no los dos? Body colour red with black stripes down centre, onto bonnet and bootlid.
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
