  • Replies 277
Posted Images
Unfortunately not until new year now, won't start it again without the correct balancer.
She punched out a massive 200hp on 6psi with some terrible timing :rant:
Bonnet didn't shut in the end, fowled on twin turbo pipe, so that's being changed to sit lower.
Twin turbo pipe changed, bonnet closes like a dream baby :)
Pick here up monday :)
What pipe are u running out of interest? All i did to mine was remove the twin turbo badge then grind off the boss which held the badge, about 10mm off the height was saved :blush: then craved coatings gave it another fresh coat and it was just enough to clear the bonnet. Have u still cut the bonnet bracing or does your new pipe allow for this?
What pipe are u running out of interest? All i did to mine was remove the twin turbo badge then grind off the boss which held the badge, about 10mm off the height was saved :) then craved coatings gave it another fresh coat and it was just enough to clear the bonnet. Have u still cut the bonnet bracing or does your new pipe allow for this?
Hi Marko,
He didn't say (car still in workshop) other than the bonnet closes. He did say he didn't need to cut the bonnet though :blush: i'll see it on Monday and let you know. Great work you were able to make yours fit :)
I can't wait to drive it- it's been 6 months!
hahah, simon i fly into brisbane monday, i'll come drive the 4door home for you, just to get to see the 3ltr gtr up close :D
Haha My 3ltr bottom end gets sent this week finally, yay, so i might start my own 3ltr build thread soon !
Gary
Could you clarify on the "modded mounts" please :banana:
takes about 5mins.... ours literally sits on the xmember... we have to re weld removed material to bring it back up a bit :banana:.
takes about 5mins.... ours literally sits on the xmember... we have to re weld removed material to bring it back up a bit :D.
If i drop the xmember 15mms and do you think i could fit this http://img.photobucket.com/albums/v489/r32...at/DSC01070.jpg
hi-mount turbo without affecting the suspension/awd? (HKS kit which currently needs the bonnet frame hacked to clear)
Same turbo kit as this car
i dont think dropping the engine 15mm will solve the problem - besides that, when the engine twists under load it will still touch the bonnet bracing.
are u sure u want to drop the engine lower? ...i was advised by rob @ rips not to do this as it changes the geometry of some of the important components i.e. cv joints
Cheers for that Marko, guess i have to find another way to make it fit :D
sorry for hi-jacking your thread Simonster
well i cut my bonnet to fit my rb26/30 (to clear the cam shaft covers & twin turbo intake pipe) - if u dont like the look of cutting the bracing u can simply just refit the bonnet insulation & u wouldn't even know it has been modified :D
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
