the tune/dyno was done over east, i've had a few little issues to sort out before getting it retuned.
the timing did seem a bit adventurous as you mentioned, so i backed it off a bit pretty much after my first drive just so i knew it was safe up until i get my trusted tuner to give it a once over.
when it gets retuned, timing and fuel will be backed off, however i'd like to wind some more boost into it if possible.
  • Replies 63
Posted Images
cheers simon
i'm getting it all tidied up and what not to get it rego'd/permitted for WA at the moment.
then after that i've got a few things to put on/remove before it goes in for a retune, hopefully i can gain a bit more midrange rather than a very peaky power graph..might make it a bit 'easier' to handle too, 1980 design suspension isn't exactly up for for a 400hp kick!
  • 4 weeks later...
  • 4 weeks later...
NOTE:
You may have noticed this thread has been moved.
SAU Admin have decided to run a new section for "Projects, Overhauls and Build-ups"
As such your thread is a prime example of what we wanted to house in this section.
We have left links in the sections you originally posted also to allow easy access to the threads new home.
Any issues, please feel free to pm myself or N1GTR.
Cheers Col
nice car mate well done. couple of little things i may have done differently but overall its a really nice tasteful car
i'm acutally working on a 31 at the moment, not quite as unique as your's, its only a aussie r31 Ti, but has copped new motor and manual conversion. removed moulds through the doors, dog legs and front gaurds & shaved locating holes, boot lock, arial and shaved rear garnish and a line or 2 out of the bars its going gun metal (new honda colour) i think its actually called phantom grey or something. series 1 bonnet, series 1 lights, pintara grill with series 3 front bar with around 18mm chopped out of the sides to fit all the series 1 stuff. also is getting some balck 17'"s (6 spoke).
anyways back on topic great car mate well done.
ALSO, in regards to the questions about the "big fat superlights"
They are ROTA RB's barnd is ROTA, RB is model.
Rota sort of copy famous designs, work replica's and that sort of thing
anyway made in china (nothing against stuff made in china) I think and they do have a repution for being "brittle" but i personally have never seen a set let go. (quite a few local drift cars run them)
they are not that exspensive at all
thought i'd chuck up some info on my car...
its a 1989 Passage GT
Forged RB25DET
Polished and ported head
RB25 gearbox with short shift
Tomei technical trax 2way diff
600x300x76 FMIC and piping
KKR480 Turbo
Koni adjustable sports suspension
R33 4 pot front calipers with slotted rotors
R33 2 pot rear calipers with slotted rotors
Power FC + hand controller
PWR 42mm alloy radiator
bucket seats
Sparco hyper fang II 17x9 +15 all round
3" turbo back exhaust
Z32 AFM
750cc powerflow injectors
RB26 coil packs
700hp fuel pump
Gates timing belt
clear indicators
auto spoiler
ADThree R30 rear lip
boost, oil pressure, oil temp, coolant temp gauges
few other bits and pieces...
spending a bit of time tidying things up now.. main focus is the engine bay at the moment..
looked like this when i bought it..
after a bit of cleaning/removing/hiding, its now like this... need to get a greddy plenum to get it how i want it thought.. thats the next purchase
A piece of shit and three quarters.
R35 GTR Fan = Dick head post of the year.
I dunno why but ive always had a soft spot for 31's
And i gotta say thats the best power curve ive ever seen outta a KKR480...I was turned off buying one due to the lack of power and response....but seeing your results is making me 2nd guess my choice to go high mount and ext gate
  • 1 month later...
mate one word GORGEOUS,
love the pillar-less windows,
n the the rims are very nice, personally i think it looks nicer without the red pinstripe, but cant see it from a wider angle so cant really tell.
one day my 31 will be close, i hope
nice work mitch :)
cheers guys.. should probably update it a bit..
got 2 new sets of rims.. some 17" Buddy Club P1's, and 17" 2 piece Work Meister S1's
just had the P1's powder coated black, need to get around to doing the same with the meisters.
And might look better if the tires actually fitted the rims?????????
i got 225's on 9.5's you gonna have a go at me?
loving the car btw. looks like a very clean 31
Edited by 32_Dave
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
