3yrs old
18,000kms
needs oil line and requires an actuator
bolts onto standard water lines
checked over by Bill at ATS (marion rd, adelaide) and said to be in top notch condition
seals are said to be all good same goes for bearings and shaft play is near non existent
great for an RB20
good on an RB25
$500 pickup
$550 delivered Australia-wide
https://www.sau.com.au/forums/topic/268031-used-slide-turbo/
was on Stagea rb25 auto, stock injectors, safc/sitc/fmic/040 fuel pump/exhaust got 206rwkw
sliding performance listed these turbos at 250rwkw @ 1.1bar
definately no lag, was same as stock turbo but a hell of a lot more punch, and sounds pretty whooshy too
made a huge difference to the engine, this turbo is how the stock nissans should have been made.
stock water lines should be a M24 bolt so yes they will fit
oil line is a M17 bolt and I made a braided unit.
the stock one will fit BUT you'd have to derestrict the oil line slightly with a .8mm drill bit as this turbo needs more oil than the stock turbo
for sale is the turbo only, no lines no other bits. bolts onto rb20/25.
search around this site "sliding performance highflow turbo 2006" for pictures on the oil line modification
with manual gearbox, bigger injectors, power-fc & support mods Id say the turbo should pull 230-240rwkw
cheers
great for an RB20
good on an RB25
Will be pretty damn great on a 25 too!
Wont be that laggy on a 20 and wont be laggy at all on a 25 and should be good for approx 250rwkw.
Would buy this for sure if i didnt find one a month or so ago.
GL with the sale mate, Very cheap!
ok so it comes with a braided oil line and that will fit in a rb20?
i dont no what you mean by drilling a hole? lol
no for sale is the turbo only
you'll need to either use your stock oil line, a .8mm drill bit and open up the restrictor before bolting on (search sliding performance high flow turbo pics - http://www.skylinesaustralia.com/forums/Sl...formance+turbo)
or you'll need to purchased a new oil line
my oil line is buggered, trust me you dont want it..... its been bolted on/off/on/off a few times, & being far too tight its cracked. thrown away.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
