Item: s13 180sx
Item Condition:not running, no turbo or ecu, cams are also removed. rest of car is good condition
Reason for Selling: need the cash
Price and Payment Conditions: $6000 slightly neg
Extra Info:
1989 180sx.
gunmetal grey.
vertex bodykit
avs 17' rims, nankang ns2 tyres with good tread.
rb20det sitting in it, cams are removed (but still have them), no turbo or ecu. the rest of the gear is all there.
r32 crossmember. so drop in another rb20 or rb25. or put the one in there back together.
it has
a turbosmart frp800 rising rate fuel reg
stock injectors and also have 570cc injectors as well if you want to go big turbo
aluminium radiator with two 12inch thermos
front mount and all stainless steel piping to suit rb
turbosmart dual stage boost controller
gates racing timing belt which is only a few months old.
clutch is a custom item by NPC clutches
its an exedy 5 puck ceramic buttom with a modified GTR pressure plate.
R33 LSD
one peice tail shaft.
ISC N1 coilovers (height, damper, camber adj)
cusco big sway bars
rear strut brace
Brakes are S14 4 pot calipers up front with DBA slotted rotors
rear are stocko S13
Inside it has Recaro SR3 seats with bride rails.
Momo steering wheel
pioneer cd player, ipod integrated.
pioneer front splits
stripped rear interior.
digital speedo and original heads up display still works!!
pivot sleepy eye controller
would make a fantastic track car with the right motor setup handles fantastic
would love to get it on the track myself but just cant afford it.
Pictures:
Contact Details:
Alan, 0404 620 229
https://www.sau.com.au/forums/topic/268046-180sx-make-great-track-or-drift-car/
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
