hey guys
i found a car list
cars that are in bold are ones i will probably buy
2006 Aston Martin DBR9
2009 Audi R8 LMS
2008 Audi R8
2008 Audi RS 4
2007 Audi S3
2007 Audi TT 3.2 quattro
2006 Audi S4
BMW M3 E36
BMW M3 E46
BMW M3 E92
2008 BMW 135i Coupé
2009 BMW M3 GT2
2007 BMW Z4 M Coupé
2008 Bugatti Veyron 16.4
2006 Dodge Challenger Concept
2008 Dodge Viper SRT10
Vaughn Gittin Jr's 2010 Falken Tire Ford Mustang GT
2010 Ford Shelby GT500
2007 Ford Focus ST
2006 Ford GT
2006 Need For Speed Shelby Terlingua
1996 Ford Escort RS Cosworth
2010 Chevrolet Camaro SS
2006 Chevrolet Cobalt SS
2006 Chevrolet Corvette Z06
2006 Honda Civic Si
2000 Honda S2000
2006 Koenigsegg CCX
2008 Lamborghini Gallardo LP560-4
2007 Lamborghini Murciélago LP640
2007 Lamborghini Reventón
2006 Lotus Elise 111R
2007 Lotus Exige S
2005 Maserati MC12 GT1
2008 Mazda MX-5
2006 Mazda RX-8
1995 Mazda RX-7
1994 McLaren F1
2007 Mercedes-Benz SLR McLaren 722 Edition
2007 Mercedes-Benz SL65 AMG
2008 Mitsubishi Lancer EVOLUTION
2006 Mitsubishi Lancer EVOLUTION IX MR-edition
2003 Infiniti G35 (V35)
1997 Nissan 200SX (S14)
2009 Nissan 370Z (Z34)
2006 Nissan 350Z (Z33)
2009 Nissan GT-R SpecV (R35)
2008 Nissan GT-R (R35)
2000 Nissan Silvia (S15) spec.R AERO
1999 Nissan Skyline GT-R (R34)
1972 Nissan Skyline 2000GT-R
1992 Nissan 240SX (S13)
2006 Pagani Zonda F
2010 Pagani Zonda R
2008 Porsche 911 GT2
2009 Porsche 911 GT3 RSR
2006 Porsche 911 GT3 RS
2004 Porsche Carrera GT
2007 Porsche Cayman S
2008 Renault Mégane RS
2007 SEAT Leon CUPRA
2006 Subaru Impreza WRX STi
2007 Lexus LF-A Concept
2008 SCION tC
1986 Toyota Corolla GTS (A86)
2008 Volkswagen Scirocco
2006 Volkswagen Golf GTI
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
