Yellow R33 Gtst 1996 Series 2 Skyline. Ultimate Mod List.
This car is extremely clean inside and out. Would be the perfect package for someone who does not want to waste a ton of time and money building an ultimate street car out of a r33 gtst.
Item: 1996 series 2, R33 GTS-T Skyline
Condition: Exceptional - inside and out
Reason for selling: Now its back from the workshop I have no where to keep it
Odo: 96****
ENGINE
engine rebuilt 3000km ago (just run in and tuned)
balanced crank
pressure tested block
wiseco forged pistons
eagle rods
arp rod bolts
arp head studs
big end oil mod (for better big end lubrication)
blue printed engine
jhh ported head
jhh valve springs
port matched head to manifolds
1.2mm 3 layer cometic headgasket
g ready style plenum
80mm billet throttle body
garett 35/40 with .82 rear housing
42mm External wastegate (plumbed back into the exhast for legality)
stainless steele high mount exhaust manifold (modified for better wastegate flow)
tomie poncams 256/256 8.8mm lift
adjustable exhaust cam gear
os giken twin plate clutch
red line gear box oil
stelth plumb back blow off valve (legal)
custom intercooler piping
600x300x76mm front mount intercooler
oil cooler (mounted behing front bar)
speedflow fittings
braided lines
550cc Nismo Injectors
Splitfire Coil packs (brand new)
N1 OIL PUMP
Genuine Nissan Water Pump
New idle'r bearing
BLITZ SBC ID iii D SPEC Boost Controler
Power FC & hand controller
fuel pressure regulator
bosch 040 fuel pump
gates pro series timing belt
custom 3" turbo back exhaust in stainless steele
3" high flow cat
Z32 air flow meter
K&N pod filter (mounted in front guard for cold air, bolted in for legality)
full s2 mspec body kit with rear pods still intact
iridium spark plugs
blitz oil catch can
95,000 km's on dash now
gearbox has OS 4th and 5th gear set, fitted by Diff Laping at kedron
RDA slotted rotors all round
piston kits on all calipers
paduate race pads all round
dot 5 race fluids in the brake system
reconditioned master cylinder with bored out piston for greater response and feeling
only ever driven with 98ron fuels
Engine built and tuned at 101 motorcafe, springwood. Tuned by Rob.
Made a very safe 408.8HP @ 19PSI ATW. Could easily push another 50-100HP out of this setup.
WHEELS AND SUSPENSION
Rims - 17" volk te37 rims powder coasted silver
Tyres - Kumo 255 rear, 235 front 95% tread (new apart from a few dyno tuning and 500kms)
1" lowered king springs all round ( sits a very legal 150mm from the ground)
bilstein shocks all round
whiteline sway bars front and rear
tomie electric HICAS lock kit with shims
INTERIOR
G-tech on dash apexi turbo timer
blitz exhaust temp gauge
blitz boost gauge
pioneer cd/mp3 head unit
pioneer 6 1/2" splits
power fc hand controller
piller mount for blitz gauges
clarion a class 12" subwoofer in boot (straped down to prevent movement)
phenix gold amplifier
mongoose 3 point battery backup alarm
driver and passenger airbags
EXTRAS
HID headlamp conversion
custom ferrari candy yellow paint job
custom front bar mods to suit intercooler
remote for head unit
1/2 breaker bar and sockets and extensions for the wheels
locking nuts
full set of nissan skyline floor mats ($400)
rear adjustable castor rods
rust free
6months rego
Mobile: 0431430153
Email: aulay AT marvelig DOT com
Price: 22K
Will take some better pictures when the sun comes out, and also post the dyno graph.
The owner of this car is a good mate of mine and ive moved overseas now but i drive a 400HP bluebird. Before he went to town on the engine i had the pleasure to go for a drive in this car and i thought there wouldn't be too many skylines that would impress me after driving my own car. - however this thing is a weapon and i wish i had the money to take it off his hands. I just want to post this up as i know first hand how much effort has gone into this car and stupid amounts of money.
The person who buys it will love it, that im sure of.
Gareth
  • 3 weeks later...
  • 4 weeks later...
 Share
    • we can only guess exactly what happened from our keyboards, but to me it looks like they were targeting 27 but the wastegate was too small or poorly controlled and the boost crept up, that is quite common
    • Good points!  Took those for granted - though I *did* actually give an example of winding boost up more than it had been before where I wasn't actually specifically looking for more peak power.  The Toyota Starlet dyno plot that I shared and mentioned showed an overlay from the previous tune it had and the one I'd redone, I left the boost targetting the same as the old tune but then after peak power I ramped boost up by a good 5psi or so over what the old tune had at the same rpm. The reason I felt comfortable with this (though the owner of the car had a "are you sure?" moment when I suggested it) is that the setup wasn't turbo limited, it was largely head sealing limited and the owner was a bit concerned as for the last few seasons he'd had issues with head lifting - sometimes not completing an event without having some headgasket issue, so he didn't want to run any more boost than it was. The reasons I was ok with raising the boost a good 5+psi MORE than that was that I left it where it was in the middle, and only increased it where VE (and therefore cylinder pressure vs psi) were dropping hard and I didn't stop the torque from dropping, just reduced the drop.  Well, there is that and the fact that the previous tuner had it overtimed by near 7degrees at peak torque - but that's another story haha.    I didn't really go into detail about that "turning it up more" thing but now you've mentioned the "not detuning", sometimes the boost *can* be turned up higher than you'd expect if the setup allows for it and you do it smartly.  I've tuned things to run 30psi on BP98 "safely" that a few years ago (or still?) people would cry that it was a stupid idea - but given they were well intercooled, low EMAP turbos and only doing that kind of boost where VE is dropping etc I was pretty confident it wasn't as cowboy as it sounded at face value and we never ended up with issues as a result of it.
    • they choose the number of psi (27) around 4200? Could it produce more at this engine speed with the same turbo?
    • one thing escapes me, if the turbo spool provides the maximum boost and we can't control anything before that, how can the boost be higher by it alone.   here around 27 psi at 4200 then up to 32 psi at 6500 rpm   how does the tuner do this
    • I'm still not sure what you are trying to acheive, but I wanted to clarify something about Lithium's response to your question...   Only within certain limits. All of the examples Lithium gave were of detuning for a particular reason. Before the engine/turbo/wastegate combination has hit full boost, you can't increase it....the wastegate is shut and the turbo is pushing as hard as it can Once the combination has hit the target (controlled) boost, you generally have full control over whether it makes more or less boost, because it is being limited/reduced from its potential. This is generally done by controlling the wastegate In the top end, with an undersized turbo, it is possible you won't get to your target boost anymore if the turbo is choking up. In this case you cannot increase boost any more without changing the setup. No change in cost compared to any decent build, other than tuning time to get the engine to make less power than it is able to at a certain point
