Hey my new Garrett turbo's are about to die i can hear a scraping grinding noise on idle its comming from one of the turbo's i took the piping off i cant reach the inlet pipe to the actual intake wheel but if i stick my ear on the pipe going to the top of the turbo as soon as i shut the car down i can hear the bearing's slowly spinning to a stop and like scraping grinding. Iv only had these turbo's for about 6 weeks is there any kind of warranty any turbo's come with? i change my oil like every 2,000km's this is bullshit. Do i have any right's to complain to my tuner workshop at all?. Thanks.
https://www.sau.com.au/forums/topic/268067-turbos-gone/
All depends on what is wrong first dude.
Without taking it off, sending it for a report, you simply do not know.
Could be poor oil supply causing the bearings to wear/fail, could be a faulty cartridge, could be poor balancing, poor housing assembly, something slightly ingested to the turbo to cause it to off balance... long list of things
Nothing you can tell, nor get angry about just yet.
Send it off to GCG for a pull apart, and you'll find out soon enough.
Generally though - There is no warranty on performance :)
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4569570
Yeah thank's mate i was sorta thinking that "There is no warranty on performance" . Ill be taking the car back to the shop on monday ask the mechanic if he can C send them off to GCG i guess.
Im thinking maybe my last turbo's died the same way i might have an oil problem. I might even have to have the motor stripped down to find out and possibly some kind of cheap rebuilt with some piston's and new bearings's new oil pump and some oil control mods, on a sorta budget :wub:. Thanks for the reply.
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4569878
Im thinking maybe my last turbo's died the same way i might have an oil problem. I might even have to have the motor stripped down to find out and possibly some kind of cheap rebuilt with some piston's and new bearings's new oil pump and some oil control mods, on a sorta budget :D. Thanks for the reply.
theres a warranty at hypergear, a 12 month warranty. i mean if theres a 12 month warranty on a chinese turbo im sure there would be a warranty on turbos purchased from garret? :wub:
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4570034
For BB turbos to have a bearing failure in that sort of time frame it means your engine oil is contaminated and it does not related to how often you you service your car. In Garrett book this type of failure is not cover by warranty. Once you change the bearing catridge in them they will be good as new. You need a in line oil filter system setup for the turbo before you put new turbos back in.
And we do not import turbos from Asian. Our turbochargers are made locally.
Edited by hypergear
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4570189
Locally made... from Chinese parts? Sorry, cheap shot but could not help it.
I wonder what Billet Turbochargers could do in terms of a rebuilt to a "higher spec" with their fancy bearings and range of billet wheels.
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4570592
theres a warranty at hypergear, a 12 month warranty. i mean if theres a 12 month warranty on a chinese turbo im sure there would be a warranty on turbos purchased from garret? :banana:
It wouldnt be a 12 month unconditional warranty - simple as that.
It would be conditional, and same as the Garrett "warranty", its highly highly conditional.
As for inline oil filters - no point.
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4570645
Unix..
I think you worry too much. :banana:
The BB Garrett turbo's all have a spinning almost slight sound when you turn off the motor.
If the bearings were stuffed you'd know about it on boost as the comp wheel will suck forward kissing the comp cover providing you with a nice loud screech. :)
Edited by TheRogue
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4570658
As for a BB turbo when it starts to faille you hear like a metal grinding noise. Some thing like Zzz.. zzzz. z you hear that when the car's switched off. Just the bearing cartridge and bearings are no longer original state as been machined off from oil contaminates. In this case we normally get customer to buy an oil filter kit or we don't service their turbos. As for a oil filter kit, Its similar a relocate kit, oil actually go through a engine oil filter before goes into the turbo. You probably see that setup often on diesel trucks and earth moving equipments.
Warranty wise its simple. All turbochargers are made to work with clean efficient oil supply which all healthy turbo engines should supply. if not then that is not considered as turbo's fault.
Locally made... from Garrett and Mellet parts.. Thank you.
Edited by hypergear
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4570791
QUOTE (bigmikespec @ 3 May 2009, 10:50 AM)
Also like to add. Half of the parts in your Garrett turbos are made in China nowa days any way. Just under different treatment and quality control. So you are sort of right.
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4570877
bearing in my gt3082r failed, no warranty, hate mtq and garret now because of my ordeal, my 2 chinese turbos lasted longer on the same motor and oil, was a dodgy cartridge im sure, i was sus on the bearing the day i got it, but they assured me its fine. didnt last a week
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4570964
oh noes !!
not even a week
ffs Id be majorly pissed off
out of interest, how did the bearings sound prior to installation, for you to question whether it was suss or normal. Obviously it wasnt normal. Who assured you it was ok??
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4570993
bush bearing are far more tolerant compared to ball bearing (garrett vs ur chinese choice)
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4571401
bearing sounded ok to me, it had a fair bit of forward and back play from out of the box, 6boost assured me it was normal and any problems i would be looked after. not the case. 6boost done all he could, no complaints there its MTQ i have beef with
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4583856
yeah but the oil wasnt MTQs failure cause, the told me originally my exhaust temps were too high, so i lolled at them then the story changed to oh no we ment there wasnt a bleed cooling system so itmelted the polymer bearing case or something, i was like wtf why is there plastic in it? he said oh nah its a polymer. im like oh ok so a type of plastic.. any who this was almost 2 years ago. just pissed cos i have had a very bad run with cars and that made it worse
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4583861
wow didnt expect to have some many replies lol, just wondering how can my oil be contaminated if its been changed 3 times in the last 7 or 8 week's? when i dump the oil it doesnt look contaminated at all. When driving the caar it doesnt seem to make a noise from the turbo's YET but on idle it defintely sounds like the comp wheel is hitting against the side of the housing hence making a screech aound but yeh cant really hear it yet when driving. I took the car back to the workshop the other day and told them they said when i strip my engine for a rebuild they can send them back to garrett and see if they will refund them or replace.
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4584312
Service the car often does not get rid of oil contamination problem. You won't be seeing them doing free warranty service or refund for sure. Thats the shit thing with Garrett BB turbos, They have very restrict border line for warranty and 99.99% time its not their fault. So you will be pissed and swearing with a dead turbo and it is bloody expansive to rebuild.
Edited by hypergear
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4584420
It would be conditional, and same as the Garrett "warranty" its highly highly conditional.
the biggest thing with garrett's warranty is that you must run an inline filter on the oil feed line otherwise they will not cover the warranty.
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4584752
Oh really that suck's bigtime then. I thought i had a problem with my oil pressure in the motor which caused the turbo problem but i just cleaned out my Oil pressure sender and my pressure has gone up back to where it used to so that musnt be the problem, Its crap caus my last trust turbo's siezed on me finally saved up for these new garrett's and the back one sounds like its gonna shit it'sself soon, If i put my ear on the pod filter at idle i can hear a high pitched weird noise like a whine. I guess ill just have to drive it untill they die and save again for new turbo's and get one of them filter's put on to the turbo's and see how that goes :D.
Edited by unix
https://www.sau.com.au/forums/topic/268067-turbos-gone/#findComment-4585906
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
