Hey all.. Just looking for abit of help on what needs to be removed so i can change my timing belt.. Im abit of a newb when it comes to engine mechanics, But id like to learn on how to do things to my own car.. Soo... I have a picture here.. And if anyone could tell me by number witch need to be removed to take off the timing belt and cam gears, that would be fantabyouless :D Thanks all. ( And yes i am getting someone to help me with fitting the new belt and gears :) )
Edited by Shadex
https://www.sau.com.au/forums/topic/268069-timing-belt-cam-gears/
Loosen 1,3 &6 to remove the belts
Then remove 5 & 4.Waterpump pulley( 5 ) is simple.
You will need a steering wheel puller to get the harmonic balancer(4) off after loosening main bolt.
Note: Before you pull the HB off make sure the engine is at TDC,( to make sure you dont stuff your timing when installing the new gears and Belt).
Then undo timing cover. Wallah.
