hay time 2 sell my 180SX... after sumthin new such as jzx100 or S15..
RECENTLY PASSED THRU REGENCY (obviously not with all the mods listed below)
DETAILS:
1997 (late) model 180SX type x
midnight purple (immaculate paint)
blacktop SR20DET (90,000 genuine kms)
5 speed
ENGINE MODS:
GT28R with all brailded turbo lines and fittings
low mount stainless manifold
D&T metal intake pipe
HKS mushroom pod
3" turbo back xhaust, str8 thru, no cat, no mufflers (LOUD)
Frount mount cooler
S15 injectors
Power FC with hand controller (tuned by Jeff at speed lab making 215.3rwkws on 17psi)
Z32 AFM
oil catch can
STEERING/SUSPENSION:
S15 5 stud conversion + s15 brakes all round
CUSCO front fully adjustable coilovers
TEIN HA rear fully adjustable coilovers
GT AOYAMA rear toe arms
GT AOYAMA rear camber arms
CUSCO front strut brace
CUSCO castor rods
WHEELS:
17x8 +30 17x9+30 koya driftteks in bronze
bridgestone tyres all round
INTERIOR:
mint type x interior with floormats
JVC cd player
Just Jap deep dish steering wheel (also comes with stock airbag steering wheel)
Blitz Dual SBC boost controller
Battery in boot with sealed box etc
$17K ono or swaps for JZX100 or S15
LOCATED adelaide SA
Contact Dale on 0433379239
PICS BELOW:
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
