Just had a few laps around the ring, haha it takes forever to do a lap! ended up with 8:01.65 mins first lap and after about 3 laps i managed a best 7:49.89 mins. Ten Four how did you manage a 7:46 lol? thats pretty impressive!
  • Replies 103
man thats nuts! thats an awesome lap time with a stock v spec. Haha i tried and tried but just couldnt get close, would always stuff up atleast one corner...also tried using the steering wheel and but then things just got worse lol. Guess i should just stick to Gran Turismo 5 prologue.
Lol cheers :rofl2: . I was getting so annoyed cause I'd stuff up a corner on a good lap..... I've got the saved reply but don't know how to load it up to a comp? I can get images on with the photo thing but not replays..
You could just play the replay on your tv and record it with a camera. It may not be the best quality or sound, but atleast you can show how you were driving.
I'll have a go at doing this with a stock r33 gtr v spec later on. I haven't played gt4 in a longgggggggggggggggg time though, but i'll see how it goes!
Just did a few laps, fastest i came up with is 7'51.042. Not too bad i guess, but i remember the corners where i made some mistakes and thats where i lost time, it was those corners where your rear wheel just touches the grass and it stuffs you up a bit. I'll try some more later though. We should also do some different tracks and cars as well :rofl2: it will be fun.
Edited by Dark26
True, ill do that later..
Just did a few laps, fastest i came up with is 7'51.042. Not too bad i guess, but i remember the corners where i made some mistakes and thats where i lost time, it was those corners where your rear wheel just touches the grass and it stuffs you up a bit. I'll try some more later though. We should also do some different tracks and cars as well :D it will be fun.
Go for it, I'll never win :) I just play GT4 for the ring..
I have xbox360
GTFO! :D
No idea lols, ps2/3 FTW :P
Edited by Ten Four
  • 3 weeks later...
I have admit that when I am really bored a good one to have a go at is the TVR Cerbera speed 12. Use it in arcade mode with traction control off...Fkn thing teaches Victor Bray a lesson or two about laying rubber... It just never stops wheelspinning ! Top gear right up to 190mph...insane
Guys is this the best game to get for Nurburgring racing or is there a better game with that course to buy?
I have xbox360
Did you end up getting Forza 2? Awesome game, and all this nurburgring talk has made me wanna have a go now :whistling:
  • 9 months later...
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
