He guys,
Im sue you have answerd this questiong over a dozzen times, but im a newbie.
I have a fair idea as to what the problem is. But i just to know what you think. I have a 32 and in the rang of 3500-4500RPM it splaters, But only does it if i accelirate suddenly. Its fine when i gradualy accelirate. So im guessing its having toubles fireing... right?? and all i need to do is gap my plugs alittle samller (0.8..??) either or its my coil packs.
What do you thing it could be?? could it be anything else??
Thanks heaps :-)
Edited by ~Aphrodtie~
https://www.sau.com.au/forums/topic/268077-splatering/
yerp.. answered your own question!
even if you do gap your plugs down your coilpacks are on the way out. there are a number of methods to alleviate the problem in the short term.. they've been covered plenty of times.. Search "misfiring" in the forced induction forum. Before long you'll get the shits with it and buy a new set of coilpacks.. Splitfire are the usual choice.
https://www.sau.com.au/forums/topic/268077-splatering/#findComment-4569886
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
