your driveway is nothing to complain about :banana: ... nothing compared to my sisters driveway ......... just be grateful you can get your car down your driveway
edit
SMITHERSNT you realise spray painting a car in the open like that isnt legal so might want to be careful
Edited by benny_blanco
  • Replies 53
Posted Images
actually i cant, thats falcon on the photo... i have to put two wooden blocks over the gutter to get r32 out... well either that or leave some fibreglass on the asphalt
but yea, i know there are even worse driveways out there...
Edited by Rocky88
i hate my driveway.
Apart from it being uneven bricks it has a power pole about 30cm from the driveway on the driverside pulling in , which results in some epic 3 wheeling action as my suspension is stiff as shit
and this is how it is when i reverse it in
Yeah ... I remember backing my Stagea up your driveway :D ... 3 point turn and angled to the road just to get up there :huh:
My driveway is a little tricky, but I got it worked out.
My 32 GTR came from japan with not 1 mark on the front spoiler lip with the front ride clearance height at roughly 112-120mm.. in 6 months ive scratched it up badly majority was driveways, the first couple of weeks of ownership was the worst, was scraping driveways and scraped a parking cement thingy but since then i've been careful as humanly possible
i always park 1 metre back to make sure i dont have any curb/car park bumper things damange mine. get given crap every now and then but i just ask them how much their bumper is worth and do a quick comparo
worst damage done to mine was done by a tow truck wanker that was too lazy to get out the boards. ended up taking twice as long when he finally gave in that needed the boards.
fortunately i dont have much trouble with driveways :P
Edited by Inline 6
Carl do you hold up much traffic trying to get in, living on a main road?
My drive is pretty flat, and the gutter section is relatively new and very wide. Also stock suspension allows me to tackle much larger inclines :P
at least you guys can get up your driveways, ours and my neighbours have a small 5cm gap between both of our driveways, no fence, and even if i go up ao a near 90 angle up his still can't get up mine. not too keen to keep trying. will post pics next time i go home.
noones driveway can beat that:
i know it looks bit wide at end, but thats no use coz there are walls at each side all the way to footpath... if there was no damn gutter in front i could get out at angle just wide enough to get out without scraping front bar
my drive way is very steep and normal cars allways nock there front bars off , council want us to pay 600 to get the curb replaced!
a cabbie once knocked his exhaust pipe off on my driveway...
$600 is a rip-off, i can buy myself $50 worth of concrete and fill the damn gutter myself if they want me to pay for it... besides gutters are their property not mine
your driveway is nothing to complain about :D ... nothing compared to my sisters driveway ......... just be grateful you can get your car down your driveway
edit
show me the legislation that states that it is an illegal activity to spray paint in the open air.
Spray Painting/Hobbies
If you undertake an activity that may generate dust, chemical spray or fumes you are required to meet your general environmental duty.
Do not:
Use spray paint in a manner which causes the paint spray to drift onto a neighbour’s property or public land.
Use organic solvents resulting in significant vapour emissions onto a neighbour’s property or public land.
If you need to touch up small areas with spray paint this should be done in your garage with the doors closed. Large spray painting jobs should be conducted in properly constructed spray booths.
Don't have your car so low if you're so worried about smashing the front bar? Or don't put over the top bodykits on?
    • Hey all, I'm working on a project car and I believe I made some mistakes. I'm looking to remove the clear coat from my car on most panels (except for panels where the paint has blistered, I will sand this), but wanted to know if these steps are correct?   1) Get a red scuff pad (abrasive one) instead of sand paper to remove the shine from the surface 2) get 400 grit sand paper and go over the entire car with a random orbital sander so the surface is smooth and the primer can grab onto something 3) On the blistered paint, go over it with around 120 grit sand paper, go to 240 to smooth out the scratches, then finish on 400 grit. Anything to add in here or any feedback?
    • Agreed, another vote for the Haltech CAN wideband.  No voltage offset errors is a beautiful thing.
    • Just get a Haltech CAN wideband, no need to wire any delay circuits, or relay, etc. Since I've moved to a Haltech CANbus wideband, I have not replaced a single sensor for over 5 years (if not longer, can't remember when moved to Haltach).
    • Small analogue delay circuit with a relay. Just need a trigger, say, fuel pump running for more than 5s or so? Or, you could go full mental and write a sketch for an Arduino.
