  • Replies 136
wakefield looks like a rippa of a circuit!
i will have to make the trip accross the border and russle some NSW feathers in the not to distant future i think... :P
Ask snowcone and scotsman when they're coming up next and tag along with them - they plan it all and you just come and make up numbers, and driiiiink :yucky:
i saw that! thought it was ben playing in the dirt :P
thanks for a great day guys
the drivers were all courteous out on the track and let me through with a minimum of fuss. the weather was great. track was great. great day :P
the fridge managed a 1:07.6. go the sr20 ;)
Bloody awesome time and very noice car!! I was the Blue S13 running in your group but only managed a few laps all day due to suspension / brake issues.
Could i pester you for a 'brief' on what you have done to the car? I punched out a 1:10 but has a lot more in it once 'issues' are sorted. i meant to come sticky beak at your car but was too busy trying to fix / diagnose my own problems!! I am always trying to get ideas on setups, more so engine / turbo choices. But if you feel like giving me a full run down i would love it!!! ahahahaha
You can post or PM me if you like :) :)
Or if you like to keep it a secret, that is A ok with me!
Cheers,
Ando
hey hey, i think your onto something there!!!
only i dont drink... :P
safety in numbers i say! it will be a victorian invasion! :P
Yeah they've had 2 of them before, send them a PM and see when they're planning the next one
Dont worry, they'll drink enough to cover your share. Chris managed to (all at the same time) park the car, drink a beer with one hand, then, using his other hand open a beer for me. And the car was parked perfectly. Its 2nd nature hahaha
You can post or PM me if you like :D:)
Cheers,
Ando
yeah, no probs ando. comeand have a stcky beak next time
I'll be out and about a few more times this year
on a down side tho, we did manage to end up with a cracked exhust manifold from the day :P
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
