  • Replies 136
wakefield looks like a rippa of a circuit!
i will have to make the trip accross the border and russle some NSW feathers in the not to distant future i think... :P
Ask snowcone and scotsman when they're coming up next and tag along with them - they plan it all and you just come and make up numbers, and driiiiink :yucky:
i saw that! thought it was ben playing in the dirt :P
thanks for a great day guys
the drivers were all courteous out on the track and let me through with a minimum of fuss. the weather was great. track was great. great day :P
the fridge managed a 1:07.6. go the sr20 ;)
Bloody awesome time and very noice car!! I was the Blue S13 running in your group but only managed a few laps all day due to suspension / brake issues.
Could i pester you for a 'brief' on what you have done to the car? I punched out a 1:10 but has a lot more in it once 'issues' are sorted. i meant to come sticky beak at your car but was too busy trying to fix / diagnose my own problems!! I am always trying to get ideas on setups, more so engine / turbo choices. But if you feel like giving me a full run down i would love it!!! ahahahaha
You can post or PM me if you like :) :)
Or if you like to keep it a secret, that is A ok with me!
Cheers,
Ando
hey hey, i think your onto something there!!!
only i dont drink... :P
safety in numbers i say! it will be a victorian invasion! :P
Yeah they've had 2 of them before, send them a PM and see when they're planning the next one
Dont worry, they'll drink enough to cover your share. Chris managed to (all at the same time) park the car, drink a beer with one hand, then, using his other hand open a beer for me. And the car was parked perfectly. Its 2nd nature hahaha
You can post or PM me if you like :D:)
Cheers,
Ando
yeah, no probs ando. comeand have a stcky beak next time
I'll be out and about a few more times this year
on a down side tho, we did manage to end up with a cracked exhust manifold from the day :P
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
