despite a number of issues with the car the shower of fuel from my tank breather hose was another. Sorry to the open-top guys who got a faceful.
I'd be happy if you would fix your car problems when YOU are told about them and not take them back out on to the track again and again. Following you around sprewing fuel everywhere is so un-cool and dangerous. You of all people should know better.
I had a great day in the Radical,,I also loved my 4 laps in the Z,,, but I hated my time in Ben's car,,,glad minimal people spotted what I did.
A BIG Thanks to everybody that run the day,,,I love you guys.
Neil.
  • Replies 136
big thanks to all who organised and helped out to make this event happen .... what a great day!!!
although got back home with 5 working sparkplugs and wounded front bar. :)
can't wait until the next one. :D
john (kuma j) ----- many thanks for the footage of my last session mate.
i saw that! thought it was ben playing in the dirt :D
thanks for a great day guys
the drivers were all courteous out on the track and let me through with a minimum of fuss. the weather was great. track was great. great day :)
the fridge managed a 1:07.6. go the sr20 :D
I want to eventually make it to a track day.
But have to wait till i get a new car now..sold the s13 on saturday :huh:
Next Stop: Subaru Liberty Wagon..
then the final stop....GT-R!!!
Not sure what model..still deciding between the R32 and R33 :D
the drivers were all courteous out on the track and let me through with a minimum of fuss. the weather was great. track was great. great day :huh:
the fridge managed a 1:07.6. go the sr20 ;)
Go Ben well done! :D
I think I forgot to thank you too Neil, so thanks. :D
dnissi that's really moving. I think SR20's sound like puss personally but I like the cars in every other way and yours puts the numbers down so well done. :huh: Very impressive.
Get it right... its a refined tractor :D
I think i seen about 8 skylines coming back from Goulburn on Saturday, a 34 (ouch), a white 32 GTR (drool) on a trailer, a red GTR, a few 33's...i figured something must have been on down there i should have come down earlier and watched =(
Jenna/Mrs Fatz here....
I think the white gtr on the trailer was us :P
Anyway, I had an awesome time and could not wipe the stupid grin off my face all day, I will definitely be back!
Thanks to all the instructors who bravely got in the car with me and helped out with all their tips and advice. I think one of the greatest things about the day was that as a complete newcomer (having never been on the track before!) everyone made you feel completely welcome and relaxed.
....and Duncan, I promise I will concentrate on braking HARDER next time!!
That's great to hear as that's what we aim for all SAUNSW days to be like :P
I had Andrews M pass me on the freeway on the way home, roof down, sunnies on, lucky bugger, wish i had a sunroof!!!!
That M was looking mighty good, would loved to have heard it flat out around the track, sweet M six...... mmmmmm
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
