will have to ask ken for that one, he purchased it from slide performance
pm him tomorrow 'KEN-R34'
for the record.. ive got my hands on an r34 gt-t too now, i cannot wait to burn this stock clutch out and put a 3 puck in it!! muahaha
Edited by snozzle
  • 3 months later...
  • 3 months later...
changing flywheel bolts is not a bad idea, if they have been used over and over you most probably want to change them, if the clutch has never been changed, i wouldnt be too fussed
the clutch install will be identical however removing and re-installing the gearbox will involve a few more steps, if you need any specific help just PM.
hope that helps
  • 3 years later...
question gents how did you guys manage to remove the topmost bolt on the exhaust side. Did you have to remove the dump pipe at all cant see anything fitting in there and its harder than even the starter bolt. This is the one i have left before dropping the box.
managed to take out that bolt i was asking about before. Now my question is i have taken all the bolts pretty certain. But the box in not dislodging from the engine. I pulled out the pin that holds the throw out bearing too
Hey Bryce, im doing it too today on my Stagea. I know the bolt your talking about, mine was even worse (GTR box is longer)!
The box should start to separate with abit of a wiggle, if not, you must have missed one.
had the same problem, as my starter motor moulding was fouling on the tunnel. Had to get really close, then rotate it to position at the last minute to line up & pop in.
Did you use a clutch aligning tool or by feel?
The aligning tool I used wasn't perfect either. You have to feel & equal the distance between the clutch & pressure plate through the three gaps where the pressure plate springs attach to the diaphragm. Tighten the bolts up evenly & oppositely. Make sure you can move the aligning tool a few times to make sure it moves.
As long as those three gaps are fairly equal, it will be pretty much spot on. This the first time I've actually used an alignment tool (the apprentice did a clutch in his 33 & I thought I'd give it a go).
  • 2 years later...
  • 8 years later...
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
