  • Replies 57
are you guys busy tomorrow? Need some heat applied to a front/dump pipe on the stagea as it lightly taps the floor and bend it a tiny bit... Could all be done on the car its just i dont have enough heat to do it myself :D
MOVING 30 SECONDS DOWN RD TO NEW SHED!!! RAN OUT OF ROOM ALREADY
NEW ADDRESS IS 2/60 STANBEL RD DIRECTLY ACROSS THE RD FROM PRO FITNESS IN PURPLE BUILDING. WE WILL STILL BE AT U3/26 STANBEL RD TILL SAT AND THEN BY MONDAY WE WILL BE COMPLETELY MOVED IN TO OUR BIGGER AND BETTER ALARMED SHED, U2/60 STANBEL RD
THANKS
Edited by SLY-L20
we dont currently have oxy to heat it but i can remake that section cheap for you!
It only needs to be bent down like 5mm at the most in one spot dont think it would be worth re-making... what would you do just cut it and weld anothe peice in their at a diff angle or something?
Its on the under side so it would need to be pulled off.
If unbolted the cat back and pulled the dump down slighlty and it bends it enough to stop it from tapping for a day or so but then it just goes back to its normal position after a day or so... :P
Ideas apart from heating it and bending it? I can get access to an oxy set on sat. which looks like the best thing to do atm but I do however have tomorrow off work and coud take it somewhere.
If unbolted the cat back and pulled the dump down slighlty and it bends it enough to stop it from tapping for a day or so but then it just goes back to its normal position after a day or so... :ninja:
Just take it to Exhaust tech or somewhere like that :P
hey guys no offense but this is a thread for our business opening not to discuss where ELSE you can take your car for a quick fix haha
Thanks guys
I am here now if you want me to have a look at it for you! Im sure we can work something out!
Simon
  • 3 months later...
    • This is a very much loved and well looked after car! - Regularly serviced and maintained - Smooth and reliable to drive - Premium model with Bose speakers, suede/leather seats, and dual climate control - Kenwood Double din DMX7522DABS stereo with USB Mirroring, Android Auto/Apple Carplay, DABS radio - 6 Cylinders 3.5L Engine -Triptronic sports automatic - 11000kms - Pearl White - Registered until August - Small fixable dent on boot and several scuff marks/paint chips.
    • Swapped the injectors around and the misfire followed. I went ahead and ordered the Deatschwerks 550cc injectors and am currently waiting for them to be ship and arrive. In the meantime, I've had my Nistune soldered to the ECU. Tested it, and and tried it out with the software. Everything should be prepared for when the injectors arrive.
    • Yeah they charge a little extra for mods , last year I noted no mods but I did have an exhaust fitted after that so  better to let them know cause these kinds of things can cause the policy to be void if you ever need to claim.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
