i just changed the inlet manifold gasket on my gtr, got it all back together, started it up and it started hunting really bad. i had a look on data scan and it said there is a detonation sensor fault. so i want to know where the sensors are or if anyone would know what i've done to it
cheers
https://www.sau.com.au/forums/topic/268132-r32-gtr-idling-problem/
You didn't go and clean the throttle bodies, did you?
The sensors (they are not the cause of your idle problem) are under the manifold, at #2 and #5 cylinders. You have probably just left them unplugged. (the error is not that you have detonation, but that the circuitry is faulty)
i didn't but i took them to a mechanics to clean the gasket surfaces and he cleaned the throttle boddies with wynns throttle dody cleaner he said it wouldn't remove the coating. but i guess it has so my question now is how do i get a stable idle again?
ideas anyone????
Some ideas:
Is your TPS adjusted correctly?
You have checked for boost leaks, right?
Do you have all the vacuum lines in right places? I've put hoses in the wrong places before. Get a diagram and check everything.
My Cef idles high too, around 1600. I can't figure out why so I just drive it anyway..
