  • Replies 52
sorry to hear mate, was a feeling a bit strange when i read the title, i remember seeing your car at Roe Street CPP on the weekend as i parked there too
good to hear you've got it back mate better than nothing right?
hope insurance helps mate cheers
im sorry to here this but its the sad thruth that it happens all to often..my friends r8 ute was taken the same way recently and then used for ram raids around perth......i sleep with my f**kn keys....these days................im also thinking that a alam with the four pin code would b a great investment as then if they get ur keys they still cant start the car with the pin lock on....very sorry to hear again i hope u can get here back on the road mate...
suxxs nuts man, is it a write-off?? at least they didnt wreck those sex wheels.
i always sleep with my keys, have them in my top draw i also have a flip knife under my pillow, have had for years now!! gl stealing my keys!
hope it turns out good for you, just remember, dont except the first offer the insurance company gives you, theyll try and give u the least amount possible!
until recently i worked at both fowles and pickles auctions dealing with all insurance co's..so i would see an average of 20 new wrecked cars each day....i left that job to start my own smash repair company, so my advice is pretty accurate as i know how each insurance co thinks...i know their different repair/write off percentages etc, buy back rules etc..(apart from me "inspecting" every wrecked nice car in the yards ha ha..i bought wrecked s15 too...
anyway...
1. if thats not written off then i will be speechless.....rule of thumb is rear quarter panel damage = massive job to replace., thats without rear suspension etc...
2. who u insured with?
3. insured value? agreed value or market value?
4. where is car now? cannington compound?...cops have to do forensics/dna, then insurance assessor has a look..
and my neighbours camry was stolen 3 weeks ago from burglary too...(churchlands area).car found in cannington next day, no damage at all....obviously needs locks/keys changed (780 for just the parts without labour...car still not been worked on
by allianz repairer....allianz say no lock kits available (i called toyota and they are in stock) lying cuunts)...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
