  • Replies 240
Posted Images
Sounds good Brad, bit of bad luck but sounds like you still had a ball.
I spoke to Brian tonight and he has e-mailed me through all the regs and paper work so i am going to try and make it to the Wakefield Park August 2nd and/or the Wakefield Park October 25th rounds.
Very excited. I will hopefully be in the combined sedans.
Chris you definitely need to give this a go next year, You to Ando i see you watching.
Yes watching and considering :P Just got to do the sums and see if it is a viable option this year... maybe try to get out there in Oct!!
Im out for the 2nd August - I want to give OP GP a go as much as I can before it closes :D
Also the last round of MRA is in December at OP!
I actually spoke with Brian Walden, he called me today, so Im on the mailing list now for MRA :P
  • 1 month later...
Just wanted to bump this thread.. :P
Round 3 of the MRA Series is coming up on the 2nd August at Wakefield Park... Spots are going fast so anyone wanting to enter starting thinking about it now!
Please contact me if you want any further information or check out the website MRA Website
Great form of cheap fun motorsport!! Come on guys get into it!!!!! :)
Cheers
Jess
Cheers for bumping this up jess.
I just sent an email off regarding the regs / class eligability for my car ;)
No worries!!
If you dont get a reply back soon let me know and I can help you out getting the info!
What is the car by the way??? Do you have a cage in it...
yeah will do.
ts a r33 gtst - no cage as yet...I dont wanna get one yet untill i find out what I need
Just a bolt in half cage is surfice as you would be going into sportscars class I reckon .
"Roll cages must be fitted to all cars that are competing in a competition event. Alloy cages are acceptable on cars built prior to 2000 and cars built after 2000 will have to have a steel cage. Full roll cages are mandatory for the following classes. Sedans category all class’s. Mini category Group “N” class may run as a minimum requirement a half cage. Clubman class cars must have fitted a half cage with the main hoop above the driver’s head as a minimum safety requirement. "
Seat belts/harnesses are acceptable if presented with no tears, broken stitching or signs of stretching. Buckles must be in good working order and push button attachment type belts are not acceptable . Seat belts must comply with the FIA 8854/98 or SFI 16.1 A minimum of a three point harness is mandatory but a greater point harness is recommended. Seat belt anchorage points where the original manufacture pick up points are not used must have a plate size minimum 50mm x 75mm and 3mm thick
I wanted to do this round but theres a supersprint same day at OP GP which I cant miss!
Aww I know...So spewin its on the same day!!!
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
