I have a RS Four V Days Edition Stagea for sale.
It has:
Bodykit
Dark window tinting
GTT 17" Rims
3" HKS exhaust
Pod filter
Gates silicone hoses
Splitfire coil packs
Towbar rated at 2500kg
Thule roofracks
Pioneer head unit
Pioneer 12" boxed sub
MTX front & rear speakers
500w Amp
Personalised plates
Complete 24hr satelite tracking alarm system with:
3 point imobolizer,
2 stage shock sensor,
Interior microwave sensor,
Tilt sensor,
Turbo timer,
Back to base panic switch (instant base & police call)
And other security features
$10,000 ONO
Email not304(AT)optusnet.com.au
OR call John 0410646431
Edited by inmate
https://www.sau.com.au/forums/topic/268172-1997-rsfourv-stagea-dayz-edition/
hey would u be interested in selling those r34 gtt rims?
thanks
Sure.
$10,000 and I will throw in the car for free.
Mate make me an offer on the rims and I will consider it...
  • 3 weeks later...
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
