Got the cooler and pipework off a mates r34 skyline, so i figured it would be a pretty straight forward swap
but just wondering what this is in the pipe coming off the manifold. Is it something to do with the dual stage boost?
first two pics show what im talking about, 3rd pic is the pipe that will be in its place. Which has nothing on it to transfer it over..
nope, it is there for a reason, you need to connect it up or blow off to atmosphere, which may be illegal in some/all areas. Without one can cause pressure surges and damage to turbo/engine.
1000th POST !!! woohoo
nope, untrue. you can run without one, you'll just get 'flutter'
don't really want to start a debate on compressor surge though
plenty of turbo motors came from factory without a bov, for instance the ca18det
its debatable weather you need the bov or not. IMO i'm with chook, in that you need to run one. alot of people choose not to run a bov but this is usually on aftermarket turbo setups.
also with the stock bov you just cant run it to atmo, the factory bov is designed to pass on vacuum, so you will get eratic idle and constant stalling. your going to have to get an adapter plate made up to fit it to the new pipe.
to add to this, the RB20DET out of a R32 comes factory with a bov, same engine in an A31 cefiro does not :P
yep, sorry, factory one cant blow to atmos, meant to mention aftermarket BOVs for this. But i still would not want to run around without one, especially with higher than stock boost.
http://en.wikipedia.org/wiki/Turbocharger#Wastegate
It has a bov on the new pipework, so thats no drama
i just want to know how to disconnect that one and do away with it all
Theres a line that runs down to behind the pod intake.. and a line off that one that goes up to what i think is maybe a solenoid or something with another line that runs down to the waste gate?
ok. i drew some arrows on the pic you gave. the larger pipe with the red arrow pointing to it, just block off, if you dont you will be creating a large vacuum leak. the smaller one with the yellow arrow, run it to the new bov.
Thanks heaps quick32
Been trying to find that out for hours :P
It's coming along alright so far, would be close to finishing it all in one day but im sick as hell with some sort of flu.
You can see on the right where the bov is now, hks ss. Not bad considering my mate gave the whole lot to me for $250.
Thanks jez. Pretty much got it all done, have neatly cut out the front bar to fit around it.
Just gotta get a bit of hose to run down to the bov and block off that vacuum line.
The boost sensor hose was also fitted in there too, is there an easy spot to re locate that or should i just tap a thread into the new piping and run it where it was originally?
but yeah, im done with this swine flu.. medication, beer and bed for me.
thanks guys, its been a productive day :P
Are you still using the factory boost solenoid? Some of the lines you were describing sounded like the lines to and from the boost solenoid to the actuator etc. Whereabouts are you located? I am sure another member would be happy to come around and have a look at your set-up.
Im near brisbane Kiwi.
I got it all sorted out, everything works fine except it likes stalling when i tap the throttle. Im guessing this is because ive just blocked off the pre existing plumb back pipe and not connected it to the new bov?
any way around it? Took it for a test run then up the highway through town and the girl in the landcruiser beside me found it hilarious that i stalled the auto twice trying to take off. She actually slowed down while laughing.. :P
sounds like you have a vacuum leak mate. have you checked that you hooked everything back up? there aren't any vacuum line floating around not hooked up are there? it will still run ok even if you block up the stock bov and dont run one.
how far out of bris are you?
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
