hey guys
i have tried to search up about this but cant find anything clear on what steps u have to take to get the transfer over from nsw to vic.
im looking at buying a new car but its got nsw plates on it.
i know i have to get a road worthy cert but does vic roads have to inspect the car as well?
if anyone has been through this any help would be much appreciated =]
my main concern isnt getting the road worthy just want to know if vic roads have to check over the ccar
cheers
https://www.sau.com.au/forums/topic/268200-transfering-rego-nsw-vic/
Hey Tin,
they will look over the car, but solely to check the numbers.
All you need is an appointment, a RWC and a declaration of sale from the previous owner. Make sure that includes his license number, date of birth and current address.
Good luck, bruv!
When I did mine, I let the rego run out in NSW before organising VIC rego, however:
I had a road worthy done on the car by a Vic Roads accredited centre within the 30 day limit. I took the road worthy to the vic roads office and told them it was a new registration, along with the receipt from sale (just a word doc the seller and I signed).
The lady asked how much I wanted to declare the car for even though the receipt told her. I paid my 12 months VIC rego plus stamp duty and the $90 to put my plates back on. Was just over $2K from memory.
To get the remaining rego back from NSW, I believe you need to apply to the RTA up there like you would normally do for Vic Roads down here. You don't transfer as such.
I walked out with a VIC registered car.
HTH :P
**Edit - just saw post above, they don't need to see the car, that can come up if there are any questions over the value but definately don't need to sight it. Sighting the car is more common on first rego, e.g. after compliance.
thanks guys for the help so far.
so really i just need a RWC, make an appointment and pay for new 12months reg, stamp duty is that correct?
cause the thing is the sellers rego runs out in 2 weeks =/
and say if i cant get the rwc in time that would prbly mean vic roads would have to see the car right?
Yes you are correct
If you can't get the RWC in that time, yes potentially they may want to see it as when it is does eventually get a roadworthy, it will be unregistered. I am not 100% sure if when renewing NSW rego, the car needs a pink slip at the same time but possibly get the seller to renew in NSW to buy yourself some more time then just cash the rego in up there when you are ready.
I wouldn't have thought you would struggle to get a RWC inside 2 weeks though down here, waiting lists in my experience aren't that long normally.
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
