Go the S13 Silvia.So many people go spending a fortune on AE86 Sprinters trying to be initial D...Not a good budget drifter in my opinion. Why bother when an S13 comes with the SR20 and beefier Gearbox and diff standard.Whilst the Sprinter guys have gotta spend and change pretty much everything...S13 All the way
180SX and R32 are the easiest to find a decent one but will probably take all ur budget. Could get a NA silvia but not as easy to find good manuals and wouldn't be as fun as you'd have to work harder to slide it (unless you find constantly holding WOT and kicking ur clutch like it's ur pregnant missus fun, then you will love it).
Either way, whatever you get, make sure it has coilovers and a mechanical diff as the basics. A good race seat and deep dish steering wheel (or bosskit spacer) will let you get a good driving position/hold you in place while sliding. That is almost as important as mechanical mods.
S13
Cefiro
R32
R31
My mate started with an R32, but that had a built RB25 in it. He came 2nd in the WA Drift Final Battle yesterday, not bad for his first season. The car started off as a daily, turned into a full blown drift car.
My other mate is buying a Ceffy for $1500 as a rolling unregisterable shell, and putting an RB25 engine/gear box in it. Will come in way below $10k
I'm buying an R31 for a bit of fun. Weld the diff, strip the interior and add some coilovers. Will be a lot of fun, and I'll add extras as I go along.
Plenty of options for you, just think it all through properly and you should make the right decision!
hey bd_89 have u had any luck looking through the for sale section??
came across this bad boy yesterday,
http://www.skylinesaustralia.com/forums/27...ri-t266391.html
could be what your after though maybe a bit over the top i dont know, it looks like the brakes, suspension and engine are all taken care of for ya.
anyway some very helpful suggestions in here, i just thought this sounded like what you might be interested in and around your price range :D
good luck with it mate.
anyway some very helpful suggestions in here, i just thought this sounded like what you might be interested in and around your price range :)
Hey,
Yeah ive had a look on a few forums and carsales. Seen a couple of things that are interesting just not in a position to buy for a few months (licence is on vacation). Was just interested in what people would recomend so i could figure out how much i need to save also was thinkin maybe s15 and use as a daily/drifter but the 20g+ price and the thought of bending it dont go to well.
buy my r32, i wasnt planning to sell it but just bought a house and need to focus on that at the moment.
i have been setting it up for drift, but havent actually drifted it.. and with oran park closing down, im turning my attention away fom drift and more to superlap, so a gtr build up is in the planning.
cusco coilovers, hicas bar, cradle bushes, all coolant lines, radiator and thermostat, waterpump replaced, head pulled off and checked, replaced head gasket, safc 2, 300zx afm, kakimoto turbo back exhaust, hdi fmic, 122000kms, 100000km service done, bought as a complete stocker in october 08, sept 09 rego.
its in your price range :D
pm me if your interested at all.. im happy to hang on to it for a while, when it sells it sells. it wont be getting driven much.
cheers
Linton
cheers
Linton
Lol, still gotta sell my car buy a GTR and then wait a few more months till i have enough for a drift project, thanks anyways though.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
