sorry some of u guys feel that way... if someone shows up in a lancer i aint gonna tell em, sorry u can't come on the cruise..... it's each to their own as to wat car u drive. Still hope to see some of you there... just look out for me in my BOMB!
Pawley: still debating. i ring ya whenif i arrive. hope we dont have much trouble with the cops. its a long tow back to mt gambier. :D
Miss_Nismo: i guess pawley just has a thing for R33's. lol
Yep, I'm allergic to P-plater ****wits in VL commodores doing burnouts at the sart/meet points and playing silly buggers weaving in and out of traffic/speeding etc too. The likelyhood of one of them sideswiping me are vastly greater than if I was on an SAU cruise. And don't get me started about being stuck behind low-powered bombs going through the hills, where they stay near the centre line and won't let you pass, speed up for straights etc.
I think everyone has a right to go cruising, but when you mix high performance cars like most of ours, with lower performance n/a cars like most of PF etc. ppl, then you are asking for trouble, as we have different capabilities and attitudes. Also note that the majority of SAU ppl are older and have way more driving experience, so are less likely to do something stupid (and lose control) and take a heap of ppl out. I don't think I have ever been on a PF or 4,6 and rotor cruise where no-one has had an accident, and I remember last year a Supra ended up having a head-on and an Excel rolled on the same cruise. These were both P-platers if I remember correctly.
/end rant
its as if p platers think that holdens are the only cars ever made. im a p plater driving something differant and because of that i have to cop the shit from most of the VL's in town who say im stupid for getting a nissan............ what fools if only they knew what layed underneath there holden rocker cover. lol
anyway. il be able to tell ya weather im going by lunch tomorrow. if not hope ya have a good SAFE night.
Skipppy I'll hav the windows down, doors open, and 80s beats cranked at the meet spot ok, I'll be easy to find.
nightcrawler I totally agree with you. everyone is allowed to cruise, but I dont want to be part of somethin thats going to be ruined by one or more wanker drivers.
hehe yeah, sweeping generalisations aside. I know who is sensible, and who is not, and more importantly, when those that normally are sensible aren't being sensible to steer clear of them (*cough* Matty doing unintended 360s on Main North Road *cough*). Ummm is that clear as mud?
I know I am a very bad one to preach - but I like to think even when things go wrong I still have a pretty good idea what to and not to do.
Originally posted by TIMMMAYYY
dean your on your p's aren't ya? hehe.
umm NC you realise that missssscheeky is on her P's dont you lol... not 4 long though!!
**COUGH**
Timmy it took my 6 years but I hold a full licence thank you!!!
haha.. Im a hoon.. deal with it.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
