hey all
went down south this weekend and was suprised at how my fuel consuption went.. went from carine caltex to capel and then back to the same servo and did some quick math and got 9.8L per 100km. sure this comprised of majority off boost driving but when i drive around too and from work i am almost using 55L for 350 km (15.7L/100km) and that is also off boost drivng apart from 2 WOTs on the way home (onto ried and freeway) and when i drive with a bit of boost i struggle to get close to 300km.
just some "fuel" for thought
pardon the pun
Dan
https://www.sau.com.au/forums/topic/268281-98l100km/
  • Replies 44
daniel, why is your fuel so bad?
should be getting at least 400 to a tank
I'll be lucky if i get 300-350kms in city driving in my r33....
I dont drive off-boost all the time, but even if i try to actually drive nicely in city driving and get as much out of a tank, i'll still only get 350kms max....
Anywho, my car needs a tune....
https://www.sau.com.au/forums/topic/268281-98l100km/#findComment-4572329
Check your boost guage. I have two seperate ones that run seperate lines. They both say -13psi when crusing at 100km in 5th at like 2700rpm. That is not ON boost. But if I then accelerate, because its high enough rpm for my turbo tohit full boost by 3000rpm. If u slowing push in the accelerator to hold a speed, then it will not be on boost, so hold it there to cruise. BUT if you accelerate hard and slowly let ur car come to a constant speed, then it will be on boost more so like -9psi, and u will hear ur turbo.
An engine is designed to accelerate. But if u want a constant speed it is throttled (less air is given) so it doesn't speed up. Hence crusing.
https://www.sau.com.au/forums/topic/268281-98l100km/#findComment-4572856
yeh i have no idea aye its def due a retune. its been 2 years.. i have tried all the other little things like o2 replacement i have a cat the only fuel mod i have is a pump on standard injectors and reg.. hmmmm
so me usage isnt as good as i thought.. bummer
https://www.sau.com.au/forums/topic/268281-98l100km/#findComment-4573353
i done a check on mine a couple of days ago and getting 12.5l/100 or 400ks to 51 ltrs. alot of traffic driving. im pretty happy with that. hopefully it wont change to much when i fit the 600cc injectors and PFC and wind the boost up. (hopeful thinking). still running the auto diff, think that is 4.3 too
Edited by Pal
https://www.sau.com.au/forums/topic/268281-98l100km/#findComment-4573958
change your oxygen sensors if you want better fuel economy ppl! if that dont work, flow test your injectors and repair/replace if neccessary, my r33 averages 420/430km to 50L of city driving and im on boost alot, pretty good for a 6 id say
my s14 would get 500kms to 50L :P
https://www.sau.com.au/forums/topic/268281-98l100km/#findComment-4575113
    • That’s a beautiful setup Tao, Have u done any development with the new Turbosmart 40mm electronic straight gate, especially in this G30 configuration?
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
