I am taking my car to the mechanics ASAP anyway and it won't be driven again till fixed, but just wondering what it could be??? My 33 is leaking LARGE quantities of oil from behind the pulley on the crank. It took a while to find, as there is oil everywhere under there now. Do you think it could be the crank case seal?? Is there anything there or just above there that has oil pressure?? It doesn't leak while sitting there but as soon as you start it you can see it dribbling out to the floor. Obviously when on the move it sprays the whole underside of the car and man does it stink! This is very uncool, it sprayed about 1 litre of oil out over a 45km journey so it is no small leak. I am a little concerned but I am thinking it should be just a seal or an oil line. What do you think?
You can say the worst, I am already thinking them!
https://www.sau.com.au/forums/topic/26829-major-oil-leak/
I first noticed the oil on the floor about a week ago, but I thought it was left over oil as I changed the oil and oil filter about a week and a half ago and have yet to master taking the oil filter off without dropping a bit of the oil and thought nothing of it. I have hardley driven the car since and have done quite a few ks this weekend and it really became a problem quickly. This has suprised me also as I have had the crank seal go in my Gemini panelvan as well and its was gradual thing over a few months and even them it was only a couple of drop over night. This really flows once the motor is started but doesn't drop a thing when sitting (if you wipe it down of cource). I am hoping it is as easy to change as the Gemini was, but unlike the Gemini I won't attempt it, I will leave it to the pros. Having to remove the donk (shudders) has crossed my mind but hopefully not. Should get it to the mechanics Monday or Tuesday hopefully.
Thanks for the input guys. Has helped to put my mind at ease, a little.
https://www.sau.com.au/forums/topic/26829-major-oil-leak/#findComment-566022
are u sure its not leaking from the oil filter ? its funny that it started leaking when u changed the oil filter. have a bettr look u maybe pleasantly surpriced to find that it leaks from the filter , maybe u havent put the o ring on ? maybe its not done up proply .
i find it hard to believe it leaks from the seal that much so quick .
anyhow u dont have to remove the donk to replace the seal , its readily avail from nissan and its not expensive , like 20 -30 $ .
a full gasket set for the engine is around 300 - 330 $.
i hope its leaking from the filter save u $ , hey its almost impossible to remove the filter without spiling some oil on the skylines . when i change mine in the gtr i put a huge rag under it then undo it so the oil goes on the rag then i quickly try to turn it up so i dont spill it , its hard though , a little easier on the the gtst , u have more room there .
anyway good luck and let us know what the prob is .
https://www.sau.com.au/forums/topic/26829-major-oil-leak/#findComment-566322
Yeah, I was hoping it was the filter not done up properly, or just some spillage, but alas, its not. Its completely dry around the filter. I had it up on ramps wiped it down thoroughly then started it, and watched it flow, not pretty. I talked to my mechanic today and he said it wasn't that expensive for the parts, just a little labour intensive and probably do the timing belt while he is there even though it was done 15000km ago. He also said it was quite rare so I am interested for him to see the problem and get his take on possible reasons. Hopefully I will get time to drop it off tomorrow afternoon.
https://www.sau.com.au/forums/topic/26829-major-oil-leak/#findComment-566443
All fixed, it was the crank case seal. The whole inside of the seal (the bit with the little spring in it) was gone all together, just the outside was remaining which explains the severity of the leak. New crank seal was $23, and he also did the two cam seals $29. He also put a new tensioner on as the bearing was a little noisey. All is good!
https://www.sau.com.au/forums/topic/26829-major-oil-leak/#findComment-571581
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
