Selling my old file server. Been sitting here for a bit now not being used for anything so thought someone else could put it to better use :D
- Antec 4bay tower case with 400W Power Supply
- Dual Intel Xeon 2.4GIG CPU's
- 2GIG DDR RAM
- 2x 250GIG SCSI HDD's
Located on the southside of brissy. Asking $1000 ONO for it.
Throw in a pretty decent video card and you got a hell of a awesome gaming machine!!!
PM me if interested.
https://www.sau.com.au/forums/topic/268317-fs-antec-computer/
JAY
just after some more specific details on wat parts are inside it.. like wat is the specs on the ram and graphics card :)
was gonna build my gf a pc.. but we will see how much ur rig is worth :laugh: im guessing ur cpu is..
Intel XEON X3220 2.4GHz 8M cache 1066FSB LGA775 ??? lol am i close?
anyways it would be much appreciated
regards jez
Edited by 32JEZ
JAY
just after some more specific details on wat parts are inside it.. like wat is the specs on the ram and graphics card :D
was gonna build my gf a pc.. but we will see how much ur rig is worth :D im guessing ur cpu is..
regards jez
not 100% sure on most of the specs.... brought this years ago for over 2k all brand new and would have since thrown the receipts and all that out.
but i'll find out what the board and ram is if the stickers are still on them.
video card not to sure myself. just says "Standard VGA CARD" in the system hardware profile list.
yeah, think that CPU listed are the ones list in this.
  • 3 weeks later...
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
