hi i was changing my spark plugs in my R32 GTR one was to tight, once i got it undone i small piece broke off and fell in the little hole. i tried to get it out with a vacuum i think i did but what is the worst that can happen ?? any help?? might happen to others ?
Cheers NightRider
get one of those magnets, i got one that extends in a screw driver set, very handy when you drop screws
I don't think that would work with ceramic. Still they are handy little things.
Edited by Doobs
you'd best get it out... you could try winding the engine over with out the plugs and see if it flies out... wear safety glasses though.. chances are it will break into more tiny pieces and just remove itself... but it could also damage a valve or embed itself in the piston... bit extreme but it would be sad to pull it down because of a tiny piece of ceramic.
i had a piece of aluminium from the throttle slide go through my wr400.. it was a substantial chunk, no dramas, it just squashed up with the heat and compression and spat it out the exhaust..
the worst that could happen? new engine. piece breaks up, damages piston, things start falling apart, catastrophic engine failure. the best that can happen? nothing at all, it gets blown out the exhaust and somehow doesn't damage your turbo.
my advice would be try as hard as you can to get it out before starting this engine. you do not want it bashing your piston to pieces. a dropped piece of plug (usually tip) or dropped valve head is a very common cause of engine failure. and it can be very final.
to get it out, try getting the piston to tdc with the plug out and get a piece of insulated wire or blow compressed air in small bursts in there to get the piece to where you can see it
when you can get some stiff wire and wack a dop of grease on it
slide it in till you contact the ceramic piece - it will (if not too big) stick to the grease and bobs your uncle out it comes
same thing happened to me on an l20B - different motor but same principle applies
it was just after a rebuild to so the last thing i wanted to do was take the head off again or risk smashing up the piston or valve seats
just takes plenty of patients and you will get a sore back, swearing really loudly helps alot.
or you can do it the easy way a piece of garden hose or hose small enough to fit through spark plug hole on the end of a vacuum cleaner (taped on so it sucks) and an empty vac bag get the piston half way then vacuum it out just check the bag after cause it was a new bag or even better a bagless vacuum cleaner you will know when ya have it.
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
