my sets of wheels
1st- AVS model 5 17x8/9 cant remember offsets federal 595 SS tires
2nd- Panasport G7 17/8.5/9.5 cant remember offsets stretch wanli tires
3rd- Enkie ?? pair 16x7 yokohama DNA GP tires
4th- TE37's 17x9 +20 Dunlop 03's
5th- Enkie NT03 17x8/9 +32/+15
6th- Work Emotion CR Kai 16x8 +30ish random tyres
7th- TE37's 17x9 +20 RE55's
8th- Weds Sports SA70's 18x10 +18 Bridgestone RE050A RFT fronts Michelin
Pilotsport RFT rears 255/35/18 all round
9th- Work Equips 18x10/12 -16/-9 something Bridgestone RE11 245/35/18 fronts no
rears yet..
loved every set :)
Axis Hiro:
You won't get as much dish on a GTS-t, but they designed the Hiros to get deep dish so even with a relatively weak offset you should have some.
Lenso D1R (aka Project-D):
Yes, the Lenso D1R won "BEST WHEELS" Award at the 10th Anniversary R34 GT-R Celebration last year.
For thinner spokes > Rays RE30 with Titanium face & Satin Silver dish.
That fitment is awesome, does it scrub it's balls off at the front?
Respect for having the knackers to go with some decent fitment and not make your 33 look like some limp wristed, sunken wheeled, wally-mobile.
Watch out for the fun police too! They'll be along soon to tell you it's impractical/your tyres are too thin for a 10 inch wide rim.
thats ur opinion, the car will prob never see more than 235's on these rim for drifting, which is what the car is built for..what part of it makes it impractical??? if i was track racing id have different size rims and tyres...whats the problem,
anyway the car looks great and the rim/tyres fill out the guards perfectly, like i said there's a bit more camber in the back so the rim just barely sticks out compared to the pic..and there is not rubbing on the front either :laugh:
I have a feeling the comment was a gee up, hence why it was a direct copy of my fun police warning.
235's on a 10" arent the end of the world, for the most part 235's have SFA stretch on a 9" so on a 10 should look toasty.
Legalities aside that is.
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
