  • 3 months later...
I'm biased, but I like XD9's
My car:
Hey looks good, what size/offset do you have on your car?
and what sort of gaurd work was done?
Edited by MatthewT85
Where were people getting the buddyclub p1 rims in 18" from, preferably matte black?
I can seem to find any retailers online that sell them.
There is the rota boost rims which are the same design and cheaper but I would like legit p1s if I can get them.
staggered set of enkei rfp1's
check out this car. looks pure dope, colour, offset and everything. im seriously considering enkeis after these shots.
http://www.stancenation.com/2011/02/21/teenage-dream/
YES! its stance nation, not all threads on there are tooooooo bad. its not like its an EG civic with 18x10s etc, i dont need to seeee anymore of those things. yock!
Blags's car
ok i know this is the wrong section but getting no luck anywhere else -
My question is , will these rims fit on my stock r33 skyline series 2. I know I probably need to get the fenders rolled but other then that , will I have issues with fitment for the rear?
They are Volk SF Challenge Zero's , old school volk wheel , came out in 97'
Front :
18x9.0 +45 235 tyres
Rear:
18x10.0 +48 275 tyres
cheers
GTR wheels are 9" +30 all round from memory and they fit on gtst's without any work im pretty sure
So, 9" at the front should be ok with a 235 tyre, thats a real high off set though.
Not real sure on the 10" on the rear, I have only really seen 9.5" on the back.
IMO With those offsets, they arent going to look great if they do fit, unless you run spacers.
Edited by Mitcho_7
To get an idea of what they'll be like, the car at the top of this page with the XD9's has (I assume) 18x10" +18 on the rear. So your wheels will sit 30mm further in than those. I had the same and they poked out about 5mm so +48 will be fairly sunken.
Put them on and see what you think anyway. I have a feeling though you may not have enough inner clearance with those offsets.
thanks for the advice , il fit it tomorrow and see how they sit.will post pics when they are on
oh and sorry for the thread jack
cheers
so they didnt fit , as suggested no inner clearance at all , what kind of spaces would I need?where would i buy it from?
oh and my vote goes for the professors! beautiful looking wheel
I'd say if you wanna go spacers you'll need 25mm bolt ons front and back. Never used spacers before so not sure where you'd get them, Justjap maybe? Best let someone else reply who'd know better for wheel studs etc.
With 25mm you'd technically be on +23 offset rear and +20 front. Will be fairly flush then if you consider my post just above yours in reply to the quoted pic. You'd be 2mm more outwards on the front and 5mm inwards on the rear compared to that black R33.
thanks for the advice, found some :
http://www.ebay.com.au/itm/NEOTECH-NISSAN-5-Stud-114-3-25mm-Bolt-Wheel-Spacers-/130708637330?pt=AU_Car_Parts_Accessories&hash=item1e6ed78692
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
    • Don't use "gasless MIG" (FCAW) you want to use proper MIG. FCAW burns a few hundred degrees hotter than MIG will for mild steel. It is a true ball ache for sheet metal. New MIG / TIG machines even have features like "Spot Weld" as well as "Automatic" settings. Plenty of people say for DIY home hobby, the auto machines are pretty good for 95% of welding. I personally, I'm a sucker for punishment and wanting to dial it in, and be able to adjust the machine. Mainly because I used to MIG weld for a living, and being able to tweak and tune things ever so slightly was my preference. Hence when I bought my ACDC TIG, it has all the adjustments for everything and no "easy" mode. Ha ha I have stick, MIG, "gaslessMIG" and ACDC TIG at home. Out of them, if you're doing mild steel sheet metal repair, and want to do mild steel exhausts, go MIG. If you're thinking you'll want to get into doing some aluminium stuff, or stainless steel, get an ACDC TIG with HF start. If you can, get one with a foot pedal too. My MIG machine is a UniMIG, and my Stick/TIG is CigWeld. If I were buying another machine, I'd buy another CIGWeld. Lots of people having issues with UniMIG, and them not wanting to cover warranty. Everything has to go back to UNIMig themselves. CIGWeld, I've had to use their warranty on my machine for a gas leak, they have repair centres everywhere, (contracted authorised repair centres). First repair place I used were hopeless, but the second place were amazing. Warranty process itself super easy, and second repair place was telling me CigWeld actually cover in their warranty, upto an hour of techs time to help you with your machine, and going through the settings and helping teach you the machine. UniMIG keep trying to get out of replacing motherboards on 12 month old machines.   TLDR, mild steel sheet welding, buy a MIG. my vote is CigWeld for brand.
    • I guess that's what happens when someone can't convert metric to freedom units to machine something. 😛
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
