yer those sp1's look pretty phat
guess its hard to go wrong with te37s
It's pretty easy to go wrong with TE37's actually, if you get weak offset they'll look very average.
na, TE-37's look shite on gts-t's / gtt's, not enough offset to get depth into the spokes. GTR only, same with LM-GT4's
Buy lower offset....problem solved
i agree totally dezz... just as long as those who go ahead and buy the lower offset realise that they may have clearance issues and are gonna have to allow for that in tyre selection, suspension and possible guard mods :closedeyes:
dayum thats hot. black and red is a awesome colour scheme. i wish i had a red skyline :P
you can.... its a respray :)
Hi there for a cheaper option I would recommend the koya drifttechs which are a multifit option 5stud for both nissan and holden and a 4 stud for 4x114.3
driftek's are 4x114.3/5x114.3 and will suit most jap cars, and falcons... commodore's are 5 x 120
I love my xd9's :)
If I didnt want to spend a fortune on wheels, I would buy some drifteks/Rotas, the rotas are better they have more concave, nice offset will look fantastic
or buy 2nd hand jap rims for the same price.... i got my professors for 2300, flawless, with 2k worth of rubber on them
*pic of blags car removed cause this post will be way too big anyway*
looks sweet as dude.... knock out some camber on the rear and it will peform/look better again!
No, its just when people put weak offsets on GTS-t/GT-t's are too weak to do any guard mods or put any effort into making good offset wheels fit. Low offset (or GTR offset, god i hate that term!) TE37's can easily fit a R33/R34, check out the S13 below. It runs 17x9.5 +12 front and 17X10 +18 rears and a S13 has much smaller guards than a R33/R34
+1 the term gtr offset shits me too as it only looks good on gtst's
and that s13 is phat... te37's will never look good without any guard work, that's the nature of the beast, but when done well they look HAWT!
JMS r33 looks good
only bad thing for most people is that r33's have those crappy wheel arches that don't look right with a flare, unless you are willing to get your rear guards flared and resprayed so you can fit some low offset wheels
hey blags
apart from the 20mm spacers did u have to do and guard mods on ur 33
cheers Nick
They didn't require 20mm spacer to fit, if that's what your asking.
The rear guards have been rolled.
The front had 20mm spacer too but with no camber they were scrubbing no matter what I did. I have taken the spacers off till I get some camber arms
i have incubus Paranormal 18# black one but they look so good it is not funny i dont have a pic of my car with them on but here is a link to the wheels http://superbuytires.com/Incubus/Paranormal/
If you guys are talking about the picture I posted up then yes, they are CST Hyper Zero's but it is an R33 sedan. Maybe the eyelids on the headlights put you off?
na realised it was a 33, but i thought they were weds sa-70's with a huge offset.... my bad
hey dude
wat are your size/offsets that dish on the bac looks sick
DO NOT put those on a skyline!
not even a holden deserves that sort of punishment!
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
