my sets of wheels
1st- AVS model 5 17x8/9 cant remember offsets federal 595 SS tires
2nd- Panasport G7 17/8.5/9.5 cant remember offsets stretch wanli tires
3rd- Enkie ?? pair 16x7 yokohama DNA GP tires
4th- TE37's 17x9 +20 Dunlop 03's
5th- Enkie NT03 17x8/9 +32/+15
6th- Work Emotion CR Kai 16x8 +30ish random tyres
7th- TE37's 17x9 +20 RE55's
8th- Weds Sports SA70's 18x10 +18 Bridgestone RE050A RFT fronts Michelin
Pilotsport RFT rears 255/35/18 all round
9th- Work Equips 18x10/12 -16/-9 something Bridgestone RE11 245/35/18 fronts no
rears yet..
loved every set :)
Axis Hiro:
You won't get as much dish on a GTS-t, but they designed the Hiros to get deep dish so even with a relatively weak offset you should have some.
Lenso D1R (aka Project-D):
Yes, the Lenso D1R won "BEST WHEELS" Award at the 10th Anniversary R34 GT-R Celebration last year.
For thinner spokes > Rays RE30 with Titanium face & Satin Silver dish.
That fitment is awesome, does it scrub it's balls off at the front?
Respect for having the knackers to go with some decent fitment and not make your 33 look like some limp wristed, sunken wheeled, wally-mobile.
Watch out for the fun police too! They'll be along soon to tell you it's impractical/your tyres are too thin for a 10 inch wide rim.
thats ur opinion, the car will prob never see more than 235's on these rim for drifting, which is what the car is built for..what part of it makes it impractical??? if i was track racing id have different size rims and tyres...whats the problem,
anyway the car looks great and the rim/tyres fill out the guards perfectly, like i said there's a bit more camber in the back so the rim just barely sticks out compared to the pic..and there is not rubbing on the front either :laugh:
I have a feeling the comment was a gee up, hence why it was a direct copy of my fun police warning.
235's on a 10" arent the end of the world, for the most part 235's have SFA stretch on a 9" so on a 10 should look toasty.
Legalities aside that is.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
