My car seems to have had the abs removed (no more abs unit with the metal brake lines coming out of it in the top right hand side of the engine bay), and is showing a 4WD fault light on the dash. After consulting the Nissan fault codes for the ATTESA ecu, it came back with:
Fault 8 ABS actuator motor, motor relay, or circuit
Fault 9 ABS actuator relay or circuit
Fault 18 ETS pressure switch or circuit
Apart from fault 18 with the pressure switch, could the other two faults that relate to the ABS (which has been removed) be causing the 4WD system to shut down?
The front wheels dont seem to have any drive, and the torque split gauge shows this as well...
https://www.sau.com.au/forums/topic/268344-abs-removal-causing-attesa-faults/
was your car always like this?
ok... well what happens is... the ATTESSA depends on the ABS sensors to operate... as well as the AWD system.
so when removing the ABS system, you need to trick the ATTESSA by rewiring a few electricals...
and apparently this does the trick.
Hi eeiko. Well I have only had the car for a couple of weeks, so can't be sure how long it's been like this for. I was thinking that tricking the system might be the way to go - any idea how this is done mate?
heya
well someone has done this before...... i think it was someone on this forum years ago
but it may be a bit fiddly with the electricals but should be pretty straight forward...
so how good are you with handy work?
I have experience with fiddly electronics, and work as a sparky so I have some idea :)
I like to tackle most things myself if possible!
there was an article i read on this
and apparently Auto sparkies dont understand how the ATTESSA works
ill have a sticky beak through and ill PM ya with details
its definately not hard to do
Hey thanks mate :P , that would be mucho appreciated! I have been doing research of my own but sometimes with these things it's like looking for a needle in a hay-stack...
I removed ABS from 32 GTR and it made no difference to anything, same with Hicas, just removed all the plugs and everything else worked same as before. Maybe the wheel sensors have been disconnected.
did you do it yourself?
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
