My Amp And Subs Are Fine, Until I Switch On The Car And I Get This Buzzing/wining Noise How Do I Fix This?
Hi guys, having some troubles here. got ur basic system 10inch running atm, amp, speakers etc, when the car is turned off and the systems running its fine, but asoon as the car is switched on theres instantly a strang buzzing/wining kinda sound, lol its getting kinda annoying now soo i think i should sort it out, i think theres some interference with the car and system? can any liners help me out there?
thanx
You said it, interferance.
I'm assuming the sound is coming out of any speakers that are on amps? (possibly all of them.) Whoever has installed it has probably run the RCAs with the power wire, or power wire for something else, and it is corrupting the RCA signal.
What I normally do in this case is get a long set of RCAs that aren't being used in a car (any shitty set will do, ask mates if you don't have any) and just run it from the source unit to the amp. For me (and probably you) that's from the dash to the boot, I normally run it outside the car as it's just a test. Try that, and if the sound goes, then there's your answer fish bulb!
There's other shit you can do, but finding out if the RCAs are being intereferred with and moving them or the power wire causing the problem is the best long term fix.
What type of RCAs do you have?
Out of curiosity, did you run twisted RCA cables? Or standard?
Twisted are said to help with interference...
some twisted pairs run near power or computers will create inductance induced noise?
try running a pair of working rca cables even 2 dollar cheapos outside the car to the boot amp. did the noise go ?
no
try the antenna wire, is it loose or unshielded, they pick up a/c from fans, etc if loose
deck grounded to metal or car harness, try the metal of the car
all power goes down one side of car if its front battery. and rca down the other side,, ALWAYS!!
otherwise look at the grounds for amp, secure, no paint
rca crossing over fuel pump harness? if so move it over or up
does the noise increase with fan on, window heater on? if so check the battery connections, clean , tight ? run a ground wire to alternator bracket bolt to ground on battery.
do you hear whine on alternator, with fan on, heater wires in window on? might be a bad alternator, have it checked with Oscilloscope for A/C ripple ?
a stiffening cap will reduce whine on amps ? removes ripple but alternator must be good to start with?
does the whine increase with rpm.... fans, heaters off? coilpack voltage leakage ? or voltage regulator issues,
might be overcharging a bit ?
name brand RCA dont fix bad whine unless a shield is broken on the old ones. the path of the rca is more critical then brand names
broken ground shield shows up if you run a new wire outside the car, it can also be a bad pre amp portion on the amp, but rare!!
hmm sounds like one of the cables is unshielded and or not shielded properly is it just buzzing or do you get like popping sounds as well ?
you could also check your ground wire
mate had the same thing cos he grounded it poorly
i had the same too now i think of it
  • 3 weeks later...
Ground for the amp. Make sure you scratch away any paint that might be in between the grounding wire and the metal you are grounding it to.
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
