R35 On Display Melbourne Cbd
CamGTS
 Share
Not sure how longs its there for, but for those that haven't seen an R35 up close yet there is a black one in the foyer of 242 Exhibition St Melbourne (Telstra building), its a public space so anyone can go and see it
Checked it out this morning, good to get up close and poke around with no one hassling you :D
Funny thing, I was walking back to my car when a Hilux mowed down a parking sign-pole right next to me, almost had to leap out of the way... he stopped and looked embarassed for a moment, then drove off... the pole was horizontal and blocking traffic and he drove off... surely you would stop and at least attempt to move the pole out of the way? some people.
They might move it out this weekend, been there for two weeks now and Telstra building displays 'usually' are only on for 2 maybe 3 weeks.
Guess i could check on Monday being i walk past 2-3 times a day
pity i didnt know, i work a few doors up(oops, read that as 242 lonsdale, i am two blocks away and pass it rarely) ...
Edited by Ryan1600
It should be on the road being driven :)
Saw an R35 driving on Toorak Rd the other day, couldn't catch up to it because of the traffic but it was pretty distinguishable from a distance.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
