Item: Brand New Focal 165 KRX2 (Newest model)
Item Condition: Brand spanking new in box
Reason for Selling: Change of plans
Price and Payment Conditions: $850 RRP is $1099
Pictures: None atm but it looks like the pic below
Contact Details: PM or post here
for more info go to the focal website
FOCAL AUSTRALIA
* 6-1/2" KRX2 2-way Component System
* Power Handling:
o Peak: 400 watts per set / 200 watts each side
o RMS: 200 watts per set / 100 watts each side
* K2 Composite sandwich cone woofer
* TN53K (Tioxid 5) inverted dome tweeter
* 2 ohms impedance
Item: JL Audio 300/2 & 500/1 Monoblock both ver 1
Item Condition: used but in good condition except for the 300/2 has 1 broken cooling fin
Price and Payment Conditions: $250 for the 300/2 & $350 for the 500/1
Pictures: Soon but it looks like the pic below
300/2
500/1
Item: Digital Design 12" Sub 2512 Model
Item Condition: Brand New
Price and Payment Conditions: $350 firm RRP $499
Pictures: Soon
120 oz magnet, Built on 9500 series technology 3000w peak / 750 RMS
for more info click here DD AUDIO
https://www.sau.com.au/forums/topic/268381-car-audio-gear/
  • 1 month later...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
