you will be very happy with the gt3582 with the .63 housing.
I had pfc, zorst, plenum, bla bla, pfc, injectors etc with a GCG GT3582 with a .63 rear.
Starts to hit boost at 2500rpm-2800rpm. Full boost by 3500-4000rpm. It didnt choke up top, it just kept pulling and pulling and pulling.
I made 240-250kw on just 16psi of boost.
It depends what u want form it tho. I want more, so i'm swapping the rear housing to a larger one.
But if your happy for a solid 250-300kw with fk all lag, and good torque, u wont be dissapointed with the gt3582.
I loved the response/torque for the street and track.
Feel free to pm me if u have any questions
All on a stock as a rock engine, internally.
Edited by r33cruiser
I made 345rwkw (22psi) with a GT35R and a 0.63 rear housing (had surge holes in compressor cover).. dyno sheets etc are in my rebuild thread from long ago (just search msnismo rebuild in FI).. In the end that was about the limit due to cat restricting flow and possibly the rear housing although it still wanted to make power. The only thing about the 0.63 rear is the power delivery was very linear and you didn't really get that kick in the guts you get with a big turbo. Hence why I upgrade to a T04Z (0.96 rear) and not as laggy as you would think :domokun:
Same setup on stock motor (including the poncams), I had it limited to 300rwkw on less boost... 16psi (could of been 18psi?) Motor blew due to other reasons, however when pulled apart all the pistons, rings, bearings were perfect except the one that picked up the metal floating (not my fault either ;) )
Either or they are both a good choice... GT30 easier to lowmount, GT35 can be lowmounted but alot of stuffing around so more of high mount scenario (and cop bait at times)
IMO putting a 700hp front end with a choking .63 rear is pointless.
Better off going a 3071 if you only want 250rwkw. It will be better in every single way.
Umm... the GT30 and GT35 use the same cartridge, comp housing and turbine housings...
So how one is 'easier' to swap and another is a bit silly as they are dimensionally the same size. The difference is the wheels inside the housings.
  • 3 years later...
If you are looking at performance these days then turbo tech has moved along to a point you don't need to stress about an in between. Get an FP HTA GT3582R, will give SFA response (if any) to the GT3082R and make more power than the GT3582R :)
I have the 3082 on my standard rb25 and at 19psi it's pushing out 420hp, sometimes I wish it was more responsive but I've never been in another gt30 variant to compare, but I don't mind it.
My next upgrade is to go the hta3582r on a rb3025 or rb32/34 25 head running on e85 flex tuned...
With a rb25/30 I'd go a hta3586r instead of the 82r version. With the extra capacity you would think it.d havd to be on by 4000rpm. And with a rb30 stroker as you mentioned I'd be looking at a hat super 94 I believe there called Lithium correct me if I'm wrong.
  • Like 1
Your welcome. There is always lots of good info coming up on SAU. You just have to keep reading and researching. But turbos have come so so far from gt3082r's I never liked the 56t 3040 anyway.
  • 1 year later...
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
