Dyno Day - Aussie Vs Imports - Springy Motors - Sat 27th Of June 2009, Need Some Nissan Cars To Represent!
5k for 400kw! thats cheating! any 400kw skylines around? i m sure there are
Im going to rebuilding my engine in the next 6 months, any one wanna donate a 600hp shot of nos to finish this engine off :)
http://www.skylinesaustralia.com/forums/Tu...88-t237291.html
Edited by W0rp3D
They will take turns running on the dyno.
A total will be calculated by the end of the day.
The highest all wheel kw will be given the win.
sorry but as i read it, they will add the 10 cars together and the total of all 10 will win? is that correct? or will it still be the highest number of all 20 takes it out?
is c fuel aloud or is it pump only??
Yep, take all the Aussie figure and add them up then take all the Jap figure and add them up and they're the final results for each class
You should definitely run your car!
Pretty sure I read somewhere that the car went bang?
^^Ujin you should have a run.
You just hit 320 kW's on your last dyno and see if Springy Motors differ in reading.
we will see how it goes.. i m still waiting on some parts to come in followed by a full tune.. if its al done in time i might enter my car lol.. :)
  • 4 weeks later...
when is the aussie vs import day going to be on, have the dates been decided? i have a gtr and a mates vz 6.0l with abit of work done to it and we are keen to chuck them on the rollers
Guest
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
    • I thought you didn't let mechanics, especially those with no idea, work on your car any more? Wouldn't that mean it won't be an issue in your case?
