just let you vic guys in on a secret. in the next few weeks I should be able to offer most parts cheaper than greenline ... and hopefully quicker too! at the moment seems as tho I should be able to offer all model power fc's for 1035 delivered, or with H/C for 1375. Will let u know when i get more info tho :P
Originally posted by dAVE
just let you vic guys in on a secret. in the next few weeks I should be able to offer most parts cheaper than greenline ... and hopefully quicker too! at the moment seems as tho I should be able to offer all model power fc's for 1035 delivered, or with H/C for 1375. Will let u know when i get more info tho :D
Can you get the same sota range as greenline for cheaper like cams, head gaskets, gauges??
If so then i will wait coz i was just about to place an order with greenline for a few more goodies!
INASNT - no promises, but I hope so. Currently my aim on the smaller items is to under cut greenlines JP price with my delivered price... saving between 50-100 on most items (still 5-20% in some cases).
Obviously there will be savings on all parts I offer. I will have final details in about 2 weeks time when i return from the Indy.
Cheers,
Dave
I normally ordered thru nengun & taka kaira.
nengun's delivery are always fast, one of the reason is I always ask nengun if the item is in stock ready to order, before sending any payments. Taka can be fast, can be slow depends on how long for the stock to ship after you submit the order. not sure if you can email them for a quote first and check if it's in stock.
Nengun:
fastest delivery experience: 5 business days
slowest delivery experience: 2 weeks
Taka Kaira:
fastest delivery experience: 1 week
slowest delivery experience: +/- 8 weeks due to out of stock item which needs to be re-ordered from Trust, so it's not actually anyone's fault.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
