Just wondering if Lukey exhaust systems and their panel filters are worth getting for my GTS-T?
Could they make me a full exhaust system? I'm talking about replacing everything!
I prefer to source quality Australian made products than paying the extra premium for Japanese aftermarket parts. I believe we can make good parts too.
Let me know what you think before I lay down my coin.
Cheers.
https://www.sau.com.au/forums/topic/268441-lukey-products/
Lukey make friggin mad exhausts.
I had one on my Datsun 280ZX and if F**King growled hard.
A rumble on idle and a roar on full throttle.
Yes I believe it was custom made 2.25" full straight though with an aftermarket exhaust manifold as well.
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4574470
Sweet. I knew they were good but I didn't know how they would go on a Skyline. I'll definetly give it a bash.
Same with the panel filter. If no one has heard of or used them then I will try and be different. Could go either way but worth a shot. I should have one in by the end of the day.
Now last but not least... Just who would be good to get the exhaust fitted from? I need someone who knows Lukey and GTS-T's that only does quality work.
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4574879
I would just stick to the Japanese brands.
They don't cost that much anyway.
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4574905
Well I have been using the Lukey panel filter for almost a week now. And I can definitely say it was worth the buy. Much better power in the higher revs and a noticeable sucking/popping sound around 5,000rpm. And there is no increase in induction noise in the lower revs so you can still hear the turbo whistle.
Anyway I will still be going for a pod filter set up later on. I will all so be going for a JJR turbo back exhaust too.
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4583917
Ah ok...
I thought you were still deciding on which brand of panel filter you want to get...
If Lukey does the job then its sweet!
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4584146
So many jap part shops have stacks and stacks of jap catbacks, I wonder what it stopping you from getting one?
I want a turbo back exhaust from the one company. If I did that from the likes of lets say HKS... Then I would be broke.
And sorry I should have been more specific.
Edited by daslingdale
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4584356
sounds like those filters do the job.
i saw your from sunbury, same hear, hope to see you round some time.
https://www.sau.com.au/forums/topic/268441-lukey-products/#findComment-4584439
    • Done about 5k Km on the PS5's now, excellent street tyres, great in the dry, and the wet, seem to be wearing very well, I haven't measured tread depth, but it looks like minimal wear, I also had a different alignment done about 1500km ago,  From looking at the tread wear, which is really only minimal, the alignment changes were based off how the tread looked, and how it felt throwing it around, the changes have shown great results 215/45 17 at 32 psi Front Caster: 5.5° Camber: -1.5° Toe: 0.0mm Rear Camber: -1.0° Total Toe-in: 1.5mm I actually prefer PS5's now over the RS4's, as the PS5's are much better in the wet IMO, and as the MX5 gets driven in all weather conditions doing daily duties, hwy trips, and blasts in the mountains, wet weather grip is high on my priority list
    • To update this thread. I got sent a replacement Attesa pro unit and all is now working as expected. Cheers
    • FD is so sexy she can pull off tri-spokes
    • Indeed they do. Best my diff builder could tell is it's a combination of the different cut/angle and it would seem they lap them in well on accell but less so on decel. He had to use a slightly different pattern to the lap to get the best result noise wise. Also as the rear diff runs in, the whine is getting less.        Overall they seem like a good thing so far. He's done a few neat crown/pinion before but all for race cars with loud everything, in most cases the exhaust is louder, so I am the first to notice.... and be somewhat of a pain
    • What do you mean by "test"? It sounds like you're just switching things on and off that you already know don't work. Get the wiring diagram and a multimeter and start looking for power where there is supposed to be power and earth where there is supposed to be earth. Look for continuity across switches that are otherwise unresponsive, etc etc.
